Installation & Licensing
New Member
triadmad
Message 1 of 8 (2,147 Views)
License system error [1.1.98]
2147 Views, 7 Replies
03-22-2006 08:35 AM
After running fine for several months, a standalone setup has started returning the following error message:
A license system error has occurred. You must uninstall and reinstall this product to initialize the license management system.
License status [1.1.98]
I found this error in the knowledge base, but it only referred to trying to run AutoCAD in Windows diagnostic mode. I still tried the instructions, but to no avail. After not getting any support satisfaction from my vendor, I followed the knowledge base instructions for performing a complete uninstall, then doing a clean reinstall. Again, I still get the error message. Any thoughts on the matter?
*Expert Elite*
TravisNave
Message 2 of 8 (2,147 Views)
Re: License system error [1.1.98]
03-22-2006 09:25 AM in reply to: triadmad
Your Autodesk Licensing Service is probably not starting or getting blocked by something.
Might try a new vendor. Where do you live?
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
New Member
triadmad
Message 3 of 8 (2,147 Views)
03-22-2006 09:26 AM in reply to: triadmad
Our office is located in Morgantown, W.Va.
*Franck Hervet
Message 4 of 8 (2,147 Views)
03-22-2006 09:35 AM in reply to: triadmad
Has the Autodesk Licensing service start after you have the error.
Don't close the dialog box error.
Franck Hervet
www.aricad.fr
a écrit dans le message de news:
5118166@discussion.autodesk.com...
Member
aviatedman
Message 5 of 8 (1,483 Views)
05-15-2012 12:49 PM in reply to: triadmad
I haven't seen anyone give an actual solution to his problem. Why is that? I am having the exact same issue.
How do we fix the problem??
*Expert Elite*
TravisNave
Message 6 of 8 (1,470 Views)
05-15-2012 02:56 PM in reply to: aviatedman
Wow, this is an old blast from the past.  Is your Autodesk license service running under your Windows services?  If not, start it manually.  Also, you didn't get a virus did you?
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=7282009&linkID=9240617
Check to make sure these exist in the registry and that you have access to them:
HKLM\Software\AutoDesk\Common Install\Shared Service\B2E1D000
AdskScSrv.exe
C:\Program Files\Common Files\Autodesk Shared\ ADSKSCVD
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=8161387&linkID=9240617
If all else fails, try this:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=4742093&linkID=9240617
Member
aviatedman
Message 7 of 8 (1,465 Views)
05-15-2012 04:46 PM in reply to: TravisNave
Thank you SO much for the list of possible fixes! I want to go through these one by one until hopefully it gets fixed. But before I start, I'm not aware on how to manually start my license service. "...your Autodesk license service running under your Windows services? If not, start it manually" If you can show me that, I will continue on through the list of info and links you sent. me. -- ~David Harris
*Expert Elite*
TravisNave
Message 8 of 8 (1,448 Views)
05-16-2012 06:51 AM in reply to: aviatedman
The easiest way is just to go to Start > Run and type services.msc and hit OK.  That will open up your Windows Services.  At that point, just make sure that the Autodesk Licensing Service is started.  Then launch your product.  If it still fails, try the other list items.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
