Installation & Licensing
New Member
nustanik
Message 1 of 3 (234 Views)
License server help
234 Views, 2 Replies
12-24-2013 08:45 AM
When I am installing autodesk 2014 ultimate I select network license. For some reason the installation still asks for a serial number and product key? Is this normal? If so then what is the purpose of going to the trouble of installing a license server??
TravisNave
Message 2 of 3 (197 Views)
Re: License server help
12-26-2013 07:00 AM in reply to: nustanik
This used to not be an issue. But now they require you to enter the proper serial/key.  Annoying, I agree.  But what you can do is just create a network deployment once and then you can install it on the clients without having to answer the steps anymore.
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
Product Support
avto
Message 3 of 3 (186 Views)
12-27-2013 07:03 AM in reply to: TravisNave
Hello and welcome to the forums.
Product installation wizard regardless of licensing method will ask you to provide the correct match of serial number and product key, so that the appropriate entry was made in ProductInformation.pit file.
ProductInformation.pit file is a very important file as it keeps track of Autodesk products installed on your system starting version 2010 and above.
XP:  C:\Documents and Settings\All Users\Application Data\Autodesk\AdLM\ProductInformation.pit
W7/W8:  C:\ProgramData\Autodesk\Adlm\ProductInformation.pit
Regarding differences between Autodesk products licensing methods, please visit the link below.
Autodesk Licensing
If you are installing your copy of Autodesk software on many computers, to avoid re-entry of serial number/product key, network license server information, I would suggest following Travis’s advice in the above post.
If you need assistance with setting up your network license server or troubleshoot network licensing issues, you can use Autodesk Virtual Agent.
1.Go to http://www.autodesk.com
2.At the bottom of the page, beneath Help and Support, click Customer Service.
3.Click the Ask button.
4.In the Virtual Agent window
5.Click “Network Licensing Help
Avto Chachava
Autodesk Product Support
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
