Installation & Licensing
New Member
tmuntz
Message 1 of 8 (327 Views)
License management and work vs home copies
327 Views, 7 Replies
10-09-2012 05:55 AM
I have recently started work at a new employer and they need help figuring out which computers on the network contain which licenses. They have purchased nine seats of design premium but throughout the history of the company licenses have been moved/switched/misplaced etc. Is there a network tool that can help easily identify which computers on the network are using which seat?
Also,
I have heard of a work copy and home copy from the same license. Can someone elaborate on the difference between the two?
Thank you.
Product Support
aaronhai
Message 2 of 8 (318 Views)
Re: License management and work vs home copies
10-09-2012 08:27 AM in reply to: tmuntz
Hi tmuntz,
Welcome to Autodesk forum community.
Within LMTools (FLEXnet License Manager), you can see the snapshot of current license users by going to LMTOOLS > Server Status tab > Perform Status Enquiry.
If you are on Subscription, you can install a separate copy at home (on top of the copy in office).
Please refer to Pg 18 / Core Subscription Benefits / C(II) Home Use Rights under Autodesk Subscription and Subscription with Advanced Support Terms and Conditions here.
Let me know if that helps.
Aaron Hai
New Member
tmuntz-b2e
Message 3 of 8 (309 Views)
Thank you, I have installed LM on my local machine. When...
10-09-2012 11:50 AM in reply to: aaronhai
Thank you, I have installed LM on my local machine. When I follow your directions I receive the following error:
The license files (or license server system network addresses) attempted are
listed below. Use LM_LICENSE_FILE to use a different license file,
or contact your software provider for a license file.
Filename: C:\flexlm\license.dat
License path: C:\flexlm\license.dat;
FLEXnet Licensing error:-1,359. System Error: 2 "No such file or directory"
For further information, refer to the FLEXnet Licensing documentation,
available at "www.flexerasoftware.com".
Should I be changing the path of the filename?
New Member
tmuntz-b2e
Message 4 of 8 (307 Views)
10-09-2012 12:00 PM in reply to: aaronhai
From what I understand:
1. I have registered with autodesk and now need to register each license online.
2. Once registered I can download the LM file from autodesk and run with the flexera software.
3 I can then manage all license from the flexera software.
Is this sounding correct?
*Expert Elite*
TravisNave
Message 5 of 8 (298 Views)
10-09-2012 01:37 PM in reply to: tmuntz-b2e
For a Quick-Start Guide on configuring the Autodesk License Manager, please see my post for further information:
http://forums.autodesk.com/t5/Installation-Licensing/Quick-Start-Guide-for-Configuring-LMTOOLS/m-p/3...
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
Product Support
aaronhai
Message 6 of 8 (289 Views)
10-09-2012 08:36 PM in reply to: tmuntz-b2e
Hi tmuntz-b2e,
A: If you are on Network licensing, you do not need to register each license online. You can request for your network license here, set it up in License Server for it to serve licenses to your client machines.
A: Yes. Travis' post provide detail instructional steps in setting up the License Manager (Kudos to Travis :smileyhappy:).
A: All client will acquire license from the License Manager.
Thanks.
Aaron Hai
New Member
tmuntz
Message 7 of 8 (272 Views)
10-10-2012 06:48 AM in reply to: aaronhai
I think my previous post may have been misleading. It looks as if we have purchased the multi-user standalone license with nine seats. Each user takes the same usb drive and installs on their local machine. My question is how can I tell which machines currently have this software installed. It sounds like the LM tools are for network licenses only. Is this correct?
*Expert Elite*
TravisNave
Message 8 of 8 (266 Views)
10-10-2012 07:53 AM in reply to: tmuntz
Correct.  NLM is only for network.  If you have a 9-seat stand-alone, then you need to install and activate 9 seats.  The automated system will not let you activate more than you're allowed.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
