Whoops. Follow up question(s):
The document does not refer to Viz specifically, but I dont think that
matters much. But how do you handle the environment variables for Viz vs.
2002? I mean, if the same servers in all offices are serving up Viz and
2002 on the same hostname, it really doesn't matter. But from what I can
tell, I'm now forced to do that. How do you config the variable on machines
running both Viz and 2002, that might need differenent LM_LICENSE_FILE
variables?
Mike
"jason martin [Autodesk]" wrote in message
news:D5B85556AF1F48AB7F4B1FB7494F5E12@in.WebX.maYIadrTaRb...
> Michael -
> If you have multiple license servers set up across the org then you are
> already using distributed licensing, you just haven't told the clients
about
> it.
> The servers, as they are set up should be fine. One server does not need
to
> know about the existence of other servers, it's the clients that need to
> know about the other servers. Take a look at
> http://support.autodesk.com/getdoc.asp?id=ts64909 and see if that explains
> it for you. If not please post back.
> hth
> jason martin
> "Michael Donahue" wrote in message
> news:7BDC73DC718A9663E9B741A8F4B7040E@in.WebX.maYIadrTaRb...
> > Hi, working with Viz 4 and AD2002. I have several flexlm servers up,
and
> > would like to use the "distributed" method of license pooling. My
> > understanding is that I need to modify each server's .lic file to make
it
> > "aware" of the other servers serving licenses. That lic file gets sent
> down
> > to the client, and if the local server goes belly up or runs out of
> > licenses, the client know to look at one of the remote servers.
> > What I'm having a hard time with is finding the proper syntax for the
lic
> > file. what exactly I should be doing, so to speak.
> > Any help would be appreciated.
> > Thanks,
> > Mike
