Installation & Licensing
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
License file appending Increment informatio n
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have registered 2 serial numbers and received 2 license files. I have seen instructions that indicate that I can simply append one's INCREMENT info into the other license file, but when I do so, I gain no additional seats with my single network license server (Windows). Is there a specific place to cut/paste the INCREMENT info?
Re: License file appending Increment informatio n
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Yes, if the license files were created on the same date, then you should just be able to add the INCREMENT portion to the other license file and it will show combined in LMTOOLS. For everything you need to know about this, check my link here:
You can also check your license files on www.licenseparser.com
Good Luck!
My Expert Contributions to the Discussion Groups: FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!Re: License file appending Increment informatio n
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thank you for the reply. In my case, I needed to add the package information as well because they are separate serial numbers. Adding just the increment portion of the license file did not provide the second license availability through the license server. The tool at http://licenseparser.com/ was a huge help in figuring that out.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Right. If they are not identical products, then you also need the PACKAGE. If you had identical products, then you could just append the INCREMENTS alone underneath the one common PACKAGE. Glad you are up and running!
