Installation & Licensing
License file and Network Deployment problem
2 REPLIES 2
skaldeway
149 Views, 2 Replies
Hi all.
We have 4 network licenses for LDT/Civil3D and 2 licenses for AutoCAD in one license file. When I install plain old AutoCAD on a workstation from the network deployment folder, it tries to use one of the LDT/Civil3D licenses and, when there aren't any available, tells me it's out of licenses. Meanwhile a quick query of the license usage tells me there are two AutoCAD licenses available.
How and where do I define what license to use from the license file for each network installation? Or how else do I fix my problem?
Thanks in advance!
2 REPLIES 2
TravisNave
in reply to: skaldeway
Are you installing AutoCAD from the plain AutoCAD disc? Or from the Civil set? That makes all the difference. Each version is encoded with a feature code that tells which license to choose.
Autodesk Forums:
skaldeway
I created the image from the plain old AutoCAD disc.
I'm going to try recreating the image today and see if that helps. Any other advice would be greatly appreciated.
Administrator Productivity
