• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    New Member
    ammaurice
    License error has occurred
    228 Views, 1 Replies
    12-22-2012 01:56 AM
    I ran into an issue tonight when I tried to run Maya 2012. I got a license error that stats I have 7 days to use Maya then I will need to repair the license. I have a commercial license that I have been using on the same machine for about a year now. When I try to repair the license it takes me through the activation, however when I try to reactivate it I am given an error 10 activation limit reached.
    When I try to use The license transfer utility it states that it is unavailable and in order to export license I must reactivate this product. Not sure what is going on can anybody help?
    Please use plain text.
    *Expert Elite*
    TravisNave
    Re: License error has occurred
    12-26-2012 10:51 AM in reply to: ammaurice
    You just need to get a manual activation code.  You might be using a 13-month home license.  You will need to get an extension for it.
    Please call Autodesk Product Registration and Authorization:
    http://en.autodesk.ca/adsk/servlet/index?siteID=9719649&id=9830778
    1-800-551-1490 > Option 1 (English) > Option 1 > (Stand-alone)
    Asia / Pacific: 65.6735.5688
    Europe / Middle East / Asia: 41.32.723.9595
    You will need to provide your serial number and the request code.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
