Installation & Licensing
License cannot be obtained
5 REPLIES 5
kjskoog
336 Views, 5 Replies
When I open Arch2008 I get an error message "Valid license could not be obtained. Try again." I recieved the license from Autodesk. Where is it suppose to go? I have it on the server with all the other Arch2008 files.
K. Skoog
CADD Technician
Kory Skoog
PM/BIM Manager
5 REPLIES 5
in reply to: kjskoog
Is this a network license? Did you create a deployment? Did you
install/update FlexLM. When you say "I have it on the server with all the
other Arch2008 files." do you mean that the program is installed on the
server or just the license manager? The license file can go anywhere on the
server as long as it is saved as an LIC or a DAT file and you have pointed
the license manager to that file.
Allen
wrote in message news:5626726@discussion.autodesk.com...
K. Skoog
CADD Technician
What does the status report running lmtools.exe on the server?
What does the debug log file says?
Jimmy Bergmark
JTB World - Software development and consulting
Owner/Developer
http://www.jtbworld.com
http://jtbworld.blogspot.com
JTB World offers you software's, custom software development, consulting...
http://www.jtbworld.com/about.htm
JTB FlexReport (FLEXnet / FLEXlm license report tool) -
www.jtbworld.com/jtbflexreport
AutoCAD 2008
http://www.jtbworld.com/autocad2008.htm
"kjskoog" wrote in message news:5626726@discussion.autodesk.com...
K. Skoog
CADD Technician
TravisNave
What is the exact error code?
Autodesk Forums:
kjskoog
Tham you for all the help. Found out it was the file servers OS that was causing the problem. IT guy redirected the Network files and changed the lmtools to locate the proper files in the new locations.
K. Skoog
Kory Skoog
PM/BIM Manager
Obviously such an error could have happened for a number of other reasons.
Mostly such things happen when someone pulls a plug on a network server or
the server software goes down for one reason or another.
One of the features in our license statistics software is to allow you to
get emails whenever the server is unavailable (e.g. goes down) this is a
useful thing allowing you to cut down on downtime. At least it can make life
easier when you don't actively have to find out if the servers are up or
not.
Good thing your problem was solved though.
Best Regards,
Henrik Goldman
Track your flexlm licenses and reduce your costs -
http://www.x-formation.com/license_statistics/index.html
Our licensing and software security blog -
http://blog.x-formation.com/
Protect your software - http://www.x-formation.com/LM-X
Administrator Productivity
