I wounder anybody know what causes license error 5.5.5 . I cant find it anywhere on the internet ? I tried to fix error online but it says my serial is invalid. The software was with a valid license until I install some software.
Any help is much appreciated.
Regards
SP
What product are you installing and what is your Operating System? Are you currently under Subscription? Have you contacted your reseller?
I am using Windows 7. what is error 5.2.2 ? I was given a laptop by my company and am working offsite for months. I have no information on subscription or reseller.
So what does the message means ?
Regards
Sp .
I need help i recently upgraded my computers hardware so i had to reinstall maya, 3ds max, motion builder, mudbox and 3ds max design all 2012 edition. Everything was fine untill i moved my c: program files and programx86 as well as my common files folders to the large part of the partition, since then autodesk verify's licence upon open and as keeps doing so i have run out of reactivations and repairs how do i fix this?
You will need to contact Autodesk Activations Department for a new activation code. 1-800-551-1490.
I have the same problen running on a Mac snow leopard, i have received several codes and continue to have these errors, i have lot's of homework (animation student) and having to wait til next morning really sets me back in my progress, is there a more permannent solution? and what is a reseller and how would that help?
You can go on-line to this address:
http://usa.autodesk.com/adsk/servlet/pc/item?id=18424632&siteID=123112
This is the quickest way to reactivate your software.
A reseller is a company that sells, supports and offers training on all or some of the autodesk software, if you look on Google you can fin one close to you, who knows if your really good in the software ask them for a job, they are always looking for good tech's.
Good luck, and use the live chat line, they are great! I was able to get a license activated in less then 10 minutes, but this is not always the case.
Robert
