• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Active Contributor
    Accepted Solution
    License Transfer or new activation?
    152 Views, 2 Replies
    10-24-2012 12:54 PM
    I apologize in advance if this has been asked but I couldn't find it. My company just upgraded my computer to a new system. We are on subscription and have 2 seats of Product Design Suite. I am the only one currently using 2013, the other user occasionally uses 2012. It has not been decided if he will use my old system or not. Should I just activate the license on the new computer or do I need to use the license transfer utility. There is currently only 1 internet connection in my office so I will be swapping the computers out as soon as I get all the programs loaded on to it. Thanks in advance.
    Donald L.
    Inventor Product Design Suite Premium 2013 SP1.1
    Windows 7 Professional - 64 bit
    HP h8-1380t - i7-3820 @ 3.6 GHz
    10 Gb
    AMD Radeon HD7950 3Gb
    Please use plain text.
    *Expert Elite*
    TravisNave
    Re: License Transfer or new activation?
    10-24-2012 01:26 PM in reply to: drlamb
    Reactivation is quicker.  Might even go automatically.  If not, just call for an activation code.  The license transfer will just annoy you.
    Please call Autodesk Product Registration and Authorization:
    http://en.autodesk.ca/adsk/servlet/index?siteID=9719649&id=9830778
    1-800-551-1490 > Option 1 (English) > Option 1 > (Stand-alone)
    You will need to provide your serial number and the request code.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Active Contributor
    10-24-2012 01:30 PM in reply to: TravisNave
    Thanks for the reply. That was my original thinking also, just didn't want to get caught in no mans land.
    Donald L.
    10 Gb
