Installation & Licensing
Member
laichiwai
Message 1 of 7 (663 Views)
License Transfer Utility returns Error 400 after subscription expired
663 Views, 6 Replies
09-27-2012 07:03 AM
I purchased 3ds Max with 1 year of subscription. It has now expired. I would like to upgrade my computer to use SSD RAID which requires the re-installation of everything.
For this, I need to backup the 3ds Max 2011 license to the Autodesk server. Sadly, the license transfer utility returns error code 400 and does not show me to log in. What can I do now?
philip.s
Message 2 of 7 (649 Views)
Re: License Transfer Utility returns Error 400 after subscription expired
09-27-2012 09:29 AM in reply to: laichiwai
Hello laichiwai and welcome to the Autodesk Discussion Groups.
As you're unable to login and utilize the License Transfer Utility, the easiest workaround is to simply reinstall the software and proceed with the standard installation / activation process.
If for whatever reason you experience an activation error, please contact our Registration and Activation team for manual assistance.
Philip Schmelzer
Member
laichiwai
Message 3 of 7 (642 Views)
09-27-2012 09:58 AM in reply to: laichiwai
Thanks for your reply, Philip.
Though, as I afraid doing a direct re-install (after re-install Windows after SSD upgrade), I will not be  granted the activation because of exceeding the limit? (I only use the activation for once only, uses LTU all around in other circumstances).
I just browsed through the Autodesk site and found out the register once link. I found there are 2 profiles under my log in. Is this normal? And it this blocking me from using the LTU? Is there any way I can check which profile I used to activate my 3ds Max the first time?
philip.s
Message 4 of 7 (637 Views)
09-27-2012 10:16 AM in reply to: laichiwai
You're very welcome laichiwai.
There shouldn't be any issues in granting you another activation code (if necessary) as your 2011 license is valid. Commercial licenses are typically allotted 2 activations / license anyway, so I doubt that you will actually need to request activation assistance.
It is normal to have multiple accounts associated with a profile, and no that would not block you form using the LTU. With that being said, I removed one as it was an empty account (no licenses attached) and wasn't adding any value. The registered contact tied to this license is the same one that you are using in the forums right now.
Please let me know if I can be of additional help.
Philip Schmelzer
Member
laichiwai
Message 5 of 7 (556 Views)
10-29-2012 07:47 AM in reply to: laichiwai
Thanks so much. I can activate the product after system refresh and installation and I can use the license transfer utility after the system refresh. Looks like my system is some how damaged and disallow the utility somehow.
New Member
gauthier.celine
Message 6 of 7 (238 Views)
09-21-2013 05:48 AM in reply to: philip.s
Bonjour,
celà fait maintenant 10 fois que je tente d'installer Autocad 2013 et que ce soit sur mon pc ou sur ma mémoire externe je me retrouve avec ''ERROR 400''
Comment faire pour activer ma licence... pour qu'elle dure plus de 30 jours?
philip.s
Message 7 of 7 (205 Views)
09-26-2013 01:31 PM in reply to: gauthier.celine
Hi Celine,
Can you please either send me a Private Message (click on my philip.s profile name and then "Send this user a private message") with your serial number + request code, or contact our License Assistance Team for direct support.
Philip Schmelzer
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
