Hello
I want to transfer my Autodesk Moldflow performance (2011) license to new computer. I understand with LTU, I can transfer license. However in Autodesk folder LTU software is not available. My soft Serial number is xxx-xxxxxxxx
Also MPA software is corrupt, can Autodesk send me Moldflow performance software CD.
I will appreciate Help.
Mukund Mehta
NYX, Inc.
36111 Schoolcraft Road
Livonia, MI. 48150
Tel: (734) 462-2385 X 292
e-mail: mmehta@nyxinc.com
Edited by
Discussion_Admin
Hello Mukund!
You're post was edited to remove the serial number. As a general rule please refrain from posting sensitive / licensing information in the public.
The LTU is compatible with standalone licenses, and would not show up in your Simulation Moldflow Insight directory as the license is running / hosted on a network.
In regards to your media inquiry, please fill out the following Media / Download Request form.
This license is single user license and not a network. My issue is to transfer existing license to new computer.
How to implement help will be appreciated
Hi Mukund,
Confirming that your license is a single seat, however it's setup as an ASP deployment (typically used with Citrix) which uses a license file and not as a standalone.
With that being said, I'd recommend contacting our License Assistance team if you need a new license file generated.
