Installation & Licensing
License Transfer Utility questions.
4 REPLIES 4
333 Views, 4 Replies
Hello
I want to transfer my Autodesk Moldflow performance (2011) license to new computer. I understand with LTU, I can transfer license. However in Autodesk folder LTU software is not available. My soft Serial number is xxx-xxxxxxxx
Also MPA software is corrupt, can Autodesk send me Moldflow performance software CD.
I will appreciate Help.
Mukund Mehta
NYX, Inc.
36111 Schoolcraft Road
Livonia, MI. 48150
Tel: (734) 462-2385 X 292
e-mail: mmehta@nyxinc.com
Edited by
Discussion_Admin
4 REPLIES 4
philip.s
Hello Mukund!
You're post was edited to remove the serial number. As a general rule please refrain from posting sensitive / licensing information in the public.
The LTU is compatible with standalone licenses, and would not show up in your Simulation Moldflow Insight directory as the license is running / hosted on a network.
In regards to your media inquiry, please fill out the following Media / Download Request form.
in reply to: philip.s
This license is single user license and not a network. My issue is to transfer existing license to new computer.
How to implement help will be appreciated
philip.s
Hi Mukund,
Confirming that your license is a single seat, however it's setup as an ASP deployment (typically used with Citrix) which uses a license file and not as a standalone.
With that being said, I'd recommend contacting our License Assistance team if you need a new license file generated.
Hi! Thanks ! got new license is working fine. Thanks Once again Mukund Mehta "CONFIDENTIALITY NOTICE: This e-mail message, including any attachments, is for the sole use of the intended recipient(s) and may contain confidential and privileged information. Any unauthorized review, use, disclosure or distribution is prohibited. If you are not the intended recipient, please contact the sender by reply e-mail and destroy all copies of the original message."
Administrator Productivity
