Installation & Licensing
Welcome to Autodeskā€™s Installation and Licensing Forums. Share your knowledge, ask questions, and explore popular Download, Installation, and Licensing topics.
Showing results forĀ
Did you mean:Ā
License Transfer Utility - Export Request Failed
51 REPLIES 51
Message 1 of 52
kim_mya
12445 Views, 51 Replies
There is a 2011 LT license that is no longer used by one of the employee. We want to transfer it to a new employee. However, the LTU won't work, it says that the serial number is not valid, but it is valid, so I don't know how I can manage to install the software on the new computer?!?!
51 REPLIES 51
Message 21 of 52
joane.bonghanoy
in reply to: ckteo12
Hi ckteo12,
Please Private Message me (click on my joane.bonghanoy profile name, and then "Send this user a Private Message") your Serial Number and Request Code.
Joane Bonghanoy
Message 22 of 52
ckteo12
in reply to: joane.bonghanoy
Hi Joane,
Did you received my reply on the serial number and request code sent
yesterday? As I have not receive any reply from you, I am uncertain if
you have received the information I sent via private message to you. For
your advise please. Thanks.
Cher Kian
Disclaimer: This message (including any attachments) is for the use of
the addressee only. It may contain private proprietary or legally
privileged statements and information. No confidentiality or privilege
is waived or lost by any transmission error. If you are not the intended
receipent, please immediately delete it and all copies of it from your
system, destroy any hard copies of it and notify the sender immediately.
You must not, directly or indirectly, use, disclose, distribute, print,
copy or rely on any part of this message if you are not the intended
recipent. Any views expressed in this message (including any
attachments) are those of the individual sender and not those of any
member of the YTL Group, except where the message states otherwise and
the sender is authorized to state them to be the views of any such
entity.
Message 23 of 52
camilo.lemos
hi ckteo12,
Joane is not in the office at the moment. If you would like to speed up the process, please forward the mentioned Private Message to me (click on my screenname camilo.lemos and then on Send Private Message).
Thank you,
Camilo Lemos
Message 24 of 52
ckteo12
in reply to: camilo.lemos
Thanks Camilo,
I have sent you the info to your private message. Thanks.
Cher Kian
Message 25 of 52
camilo.lemos
Hi Cher Kian,
Just replied to your private message,
Let me know if you need any more help:)
Camilo Lemos
Message 26 of 52
ckteo12
Thanks Camilo.
I have sucessfully activated the software. Thanks.
Cher Kian
Message 27 of 52
mika.tiilikka
I have same problem with one computer and it gives error number 1 when trying to export both licenses.
Problem is with Autodesk 3ds Max 2012 and AutoCAD Revit Architecture Suite 2010
Can I have manual deactivation also? Can I sent my license information with private message?
Message 28 of 52
Hi mika.tiilikka and welcome to the forums,
Please, send me your serial numbers via Private Message (click on my camilo.lemos profile name and then on Send This User a Private Message) and I'll have a look at why this is happening.
Best regards,
Camilo Lemos
Message 29 of 52
Hi, I've the similar problem. It said activation limit reached when I try to install my REVIT 2014 student edition on a new computer. I've uninstalled the old one already, but it still don't let me activate the program. Can you help me with that?
Message 30 of 52
mike.beale
in reply to: junxianpoon
Hi Junxian!
Are you still having issues activating your student software?
Just to explain a little, student software is only allowed one activation and any subsequent activation will produce an activation limit has been reached message. We do understand though that situations occur where reactivation is necessary such as installing it on a new computer due to the old computer having hardware issues or just wanting to upgrade.
In order to reactivate please, contact our license assistance team and provide your request code, who will then be able to generate an activation code.
Thank you for contributing to our online community!
Mike Beale
Message 31 of 52
SPYAP
in reply to: mike.beale
I have similar problem with error reference: 1
Message 32 of 52
camilo.lemos
in reply to: SPYAP
Hi SPYAP,
As per our Private Message exchange, your software has been upgraded to a newer version and an automatic activation/license tranfer was no longer possible. Your product has been manually activated by our crew.
Best regards,
Camilo Lemos
Message 33 of 52
johnn86
in reply to: kim_mya
I am having the same issue.  Just received a new company laptop and need to transfer the license but it is not working.
Message 34 of 52
akhileshjj
We had purchased Autocad map 3D 2013,We have one license of Multi user Stand alone of 6 seats,
I am one of the user & I needs to Upgrade the OS in my laptop (in which the Autocad was installed).So once the system is formatted and new OS is installed need to re-activate the autocad.I have tried using the License transfer utility for the same but i am getting error reference 1.Please suggest so that i can continue to use autocad without issues after the new OS is installed in my laptop.
Akhil
Message 35 of 52
philip.s
in reply to: akhileshjj
Hello Akhil,
Could be the issue that the license has been upgraded which would prevent the LTU from properly functioning. I'd recommend contacting our License Assistance Team for confirmation and/or manual activation assistance.
Message 36 of 52
I have same problem please help
hussainsamtan@gmail.com
Message 37 of 52
I cannot send private message. plesae help me I am getting Export request failed  message. pleease help me or give me your mail id. urgent..!!
Thanks in advance
husssain
mail id - hussainsamtan@gmail.com
Message 38 of 52
hussainsamtan
in reply to: philip.s
Thanks in advance
husssain
Message 39 of 52
Nirah.Aziz
in reply to: hussainsamtan
Hello Hussain.
Welcome to the forums!
A private message has been sent to you pertaining to this request and I will be looking forward to your response.
Thank you. šŸ™‚
Munirah Aziz
Message 40 of 52
hussainsamtan
in reply to: Nirah.Aziz
okay Thank you MMadam.
What is next?
Administrator Productivity
