Does the "zombie" timeout just check to see if AutoCAD is running on the
workstation ....... i.e. the workstation ip address is pinged every 30 sec
or so - if AutoCAD is running it maintains the license. If AutoCAD is not
open or the workstation is off-line it releases the license for somebodey
else or does it actually sense if somebody has actually been active with
using AutoCAD; not merely bogarting the license by having it up on there
screen?
James A. Lemons
CAD Systems Manager
Howard R. Green Company
P.O. Box 31039
4685 Merle Hay Road, Ste. 106
Des Moines, Iowa 50322-1966
http://www.hrgreen.com
mailto:jlemons@hrgreen.com
"Ricky M. Medley" wrote in message
news:FBA6F43416FDEDC1FE153DC87E5C4CCA@in.WebX.maYIadrTaRb...
> There is, contrarry to what a few others are saying. It's called a Zombie
> Timeout. It all depends on which sytem you are running your license
> manager. If IPX then, from the Novell command prompt, unload the license
> manager, and reload adding the extension -z and then a space, and then the
> time in seconds.
> If TCP/IP then from the workstation in which LM was loaded, goto
> Start->Setting->Control Panel. Double-click the AdLM icon. Stop the
server
> if it is running. Choose Settings. and enter the time limit for Zombie
> Timeout.
> Ricky M. Medley
> Systems Administrative Assistant
> PH:281-821-7100 Ext:579
> mailto:rickym@inddata.com
> IDS Engineering
> 600 Century Plaza Dr. Bldg. 140
> Houston, TX 77073
> PH:281-821-7100
> "Michael Pool" wrote in message
> news:F66641EED98034716E741EB00C8BC1D9@in.WebX.maYIadrTaRb...
> > Does anyone know if there is a way to set the ADLM to timeout a license
if
> > it has had no activity after a certain period of time? We are using
Land
> > Development Desktop with the Civil Design and Survey add-ons. We have
> only
> > purchased a few licenses of civil and survey for the ADLM since they are
> not
> > used as often. However, since they are loaded only on the first use of
> the
> > software and may not be used again for a while, we would like to have
the
> > ADLM get that license back if it hasn't been used in say 15 minutes. Is
> > this possible?
> > Thanks in advance.
> > Michael Pool
> > Designer, Engineering
> > RRM Design Group
> > San Luis Obispo, CA
