Installation & Licensing
License Problem on Windows 2000 Server with AutoCAD 2002 installed on a Win 2
1 REPLY 1
214 Views, 1 Reply
We installed AutoCAD 2002 on a Win 2000 Pro computer and when the user log on the server, it takes 1 license on SMB Server (which is normal), but when we start AutoCAD, the number of license on this computer jumps up to 6 licenses (which is not normal). This cause problems because we have 9 computer to log on the server and we have 10 Win 2000 server licenses. What can I do to resolve this problem??
Pierre-André Ducharme
Meubles St-Damase Inc.
1 REPLY 1
Pierre-Andre -
Are you talking about the MS license logging service?? If you are ignore it, or turn the
(*&# thing off. I've heard a number of people from microsoft recommend that people turn
it off. It doesn't work right. It counts any tcp connection to the server as a license,
which is wrong! It doesn't even work with MSExchange server. It counts a connection for a
logon, plus 3 additional connections for exchange, 1 for DS, 1 for PrivIS and 1 for PubIS.
Since the new aldm uses tcp by default the stupid windows server counts each of those
connections as licenses. (I'm not sure why your getting 6, I only knew of 2 for the adlm,
but it doesn't matter.) When you launch acad the Flexlm contacts the server on port 27000
(by default) and asks it what other port to contact and the server replies 2080
(autodesk's default port). The client then contacts 2080 and establishes a license
(that's the two that I know of). I'm not sure where you are getting the other 4, but it's
probably normal. I've not checked the license logging service on my adlm server because I
shut the thing down, and I'll refuse to turn it back on until MS makes one that actually
works.
jason martin
frankfurt-short-bruza
"HexBinarius" wrote in message news:f07c80d.-1@WebX.maYIadrTaRb...
> Thanks
Administrator Productivity
