• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    *Patnaude, David
    License Manger Not Found on NetWare Server
    97 Views, 4 Replies
    01-24-2001 12:13 AM
    I have had the license manager running on a NetWare server for almost 3
    years. Recently I have begun having problems with the license manger.
    Changes to the server would include changing from NetWare 4.11 and service
    packs to NetWare 5.0 and service packs to NetWare 5.1 and service packs.
    Users will all of a sudden receive that error message that the hardware
    lock is not found. I trie to query the license mananger and it is not
    found. Looking at the server, adskelmd.nlm still appears to be running. I
    unload and reload the NLM and all is back to normal. Any ideas why the
    license manager keeps losing its connection?
    I have also recently had trouble loading the license manager when the
    server is restarted. License manager unable to load, hit any key to
    continue. I can then manually load the NLM and it will work.
    Any help would be appreciated.
    adskelmd.nlm 9/25/1998 292,404 bytes
    David Patnaude, MCSE, MCP+I, CNA 5
    dpatnaude@tamsconsultants.com
    To reply by e-mail, remove clothes.
    Please use plain text.
    *martin, jason
    Re: License Manger Not Found on NetWare Server
    01-24-2001 12:16 AM in reply to: *Patnaude, David
    Are you by chance running tcp/ip on the nw server? If so this is not supported by the
    adlm. It will sometimes work, but it's not supported. Even if you are running tcp/ip and
    ipx/spx it "tends" not to work reliably. I've not tested it on nw5 but I've heard that if
    you go back to ipx/spx only on the nw server the adlm will function correctly.
    hth
    jason martin
    frankfurt-short-bruza
    "David Patnaude" wrote in message
    news:903372BA0dmpziplink@198.102.112.35...
    (snip)
    *Patnaude, David
    Re:
    01-24-2001 12:25 AM in reply to: *Patnaude, David
    jmartin@^nospam^fsb-ae.com (jason martin) wrote in
    >supported by the adlm. It will sometimes work, but it's not supported.
    >Even if you are running tcp/ip and ipx/spx it "tends" not to work
    >reliably. I've not tested it on nw5 but I've heard that if you go back
    >hth
    >jason martin
    >message news:903372BA0dmpziplink@198.102.112.35...
    >> 3 years. Recently I have begun having problems with the license
    >> manger. Changes to the server would include changing from NetWare 4.11
    >> and service packs to NetWare 5.0 and service packs to NetWare 5.1 and
    >> service packs.
    >(snip)
    We are running both IPX and TCP/IP on the server. We are using TCP/IP for
    the servers to communicate with each other over the WAN. I'll have to check
    with the corporate office to see if we can change that setup.
    *milana, jerry
    Re:
    01-24-2001 09:49 AM in reply to: *Patnaude, David
    David,
    The behavior you describe is often encountered when Netware Servers are
    marginal in RAM resources. Netware is going to give the file system
    priority to system memory resources. As for the errors encountered during
    reboot, they can often be resolved by moving the adlm startup string in the
    Autoexec.ncf up or down the list.
    jerry milana
    news:90337769Bdmpziplink@198.102.112.35...
    > >hth
    > >jason martin
    > >> service packs.
    > >(snip)
    check
    > Thanks,
    *Patnaude, David
    Re:
    01-25-2001 12:07 AM in reply to: *Patnaude, David
    milanaj@autodesk.com (jerry milana) wrote in
    <6059EA819B2D43214955A4CD9C53D0B8@in.WebX.SaUCah8kaAW>:
    >David,
    >during reboot, they can often be resolved by moving the adlm startup
    >string in the Autoexec.ncf up or down the list.
    >jerry milana
    Jerry,
    I have tried moving it up and down the list in the autoexec.ncf file
    without success. The server has 768 MB of RAM and is not being hit that
    hard to run low on resources.
