Installation & Licensing
*Patnaude, David
Message 1 of 5 (122 Views)
License Manger Not Found on NetWare Server
122 Views, 4 Replies
01-24-2001 12:13 AM
I have had the license manager running on a NetWare server for almost 3
years. Recently I have begun having problems with the license manger.
Changes to the server would include changing from NetWare 4.11 and service
packs to NetWare 5.0 and service packs to NetWare 5.1 and service packs.
Users will all of a sudden receive that error message that the hardware
lock is not found. I trie to query the license mananger and it is not
found. Looking at the server, adskelmd.nlm still appears to be running. I
unload and reload the NLM and all is back to normal. Any ideas why the
license manager keeps losing its connection?
I have also recently had trouble loading the license manager when the
server is restarted. License manager unable to load, hit any key to
continue. I can then manually load the NLM and it will work.
Any help would be appreciated.
adskelmd.nlm 9/25/1998 292,404 bytes
David Patnaude, MCSE, MCP+I, CNA 5
dpatnaude@tamsconsultants.com
To reply by e-mail, remove clothes.
*martin, jason
Message 2 of 5 (122 Views)
Re: License Manger Not Found on NetWare Server
01-24-2001 12:16 AM in reply to: *Patnaude, David
Are you by chance running tcp/ip on the nw server? If so this is not supported by the
adlm. It will sometimes work, but it's not supported. Even if you are running tcp/ip and
ipx/spx it "tends" not to work reliably. I've not tested it on nw5 but I've heard that if
you go back to ipx/spx only on the nw server the adlm will function correctly.
hth
jason martin
frankfurt-short-bruza
"David Patnaude" wrote in message
news:903372BA0dmpziplink@198.102.112.35...
(snip)
*Patnaude, David
Message 3 of 5 (122 Views)
Re:
01-24-2001 12:25 AM in reply to: *Patnaude, David
jmartin@^nospam^fsb-ae.com (jason martin) wrote in
>supported by the adlm. It will sometimes work, but it's not supported.
>Even if you are running tcp/ip and ipx/spx it "tends" not to work
>reliably. I've not tested it on nw5 but I've heard that if you go back
>hth
>jason martin
>message news:903372BA0dmpziplink@198.102.112.35...
>> 3 years. Recently I have begun having problems with the license
>> manger. Changes to the server would include changing from NetWare 4.11
>> and service packs to NetWare 5.0 and service packs to NetWare 5.1 and
>> service packs.
>(snip)
We are running both IPX and TCP/IP on the server. We are using TCP/IP for
the servers to communicate with each other over the WAN. I'll have to check
with the corporate office to see if we can change that setup.
*milana, jerry
Message 4 of 5 (122 Views)
Re:
01-24-2001 09:49 AM in reply to: *Patnaude, David
David,
The behavior you describe is often encountered when Netware Servers are
marginal in RAM resources. Netware is going to give the file system
priority to system memory resources. As for the errors encountered during
reboot, they can often be resolved by moving the adlm startup string in the
Autoexec.ncf up or down the list.
jerry milana
news:90337769Bdmpziplink@198.102.112.35...
> >hth
> >jason martin
> >> service packs.
> >(snip)
check
> Thanks,
*Patnaude, David
Message 5 of 5 (122 Views)
Re:
01-25-2001 12:07 AM in reply to: *Patnaude, David
milanaj@autodesk.com (jerry milana) wrote in
<6059EA819B2D43214955A4CD9C53D0B8@in.WebX.SaUCah8kaAW>:
>David,
>during reboot, they can often be resolved by moving the adlm startup
>string in the Autoexec.ncf up or down the list.
>jerry milana
Jerry,
I have tried moving it up and down the list in the autoexec.ncf file
without success. The server has 768 MB of RAM and is not being hit that
hard to run low on resources.
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
