Jerry,
No, I haven't installed anything except the two patches mentioned in my
original posting. The server is behind our firewall, so it doesn't have
anything firewall like on it. It's been FLEXlm for about two years, so
it isn't some recent change. I ran across an article in the KB
regarding port use, according to netstat nothing is using its ports.
Bill
jerry milana wrote:
> Bill,
> Have you installed any firewall or similar software? This sort of "daemon
> storm" has been known to be caused by applications stepping on FLEXlm's
> ports or intentionally blocking them. Firewall and internet security type
> applications have been the most common offenders. Both LMGRD and ADSKFLEX
> use IANA registered port numbers but there have occasions where other
> applications have used or blocked them anyway.
> Jerry Milana,
> Autodesk Professional Services
> "Bill Matson" wrote in message
> news:3E467148.9070609@bellsouth.net...
>>Jerry,
>>I already tried that, didn't help at all. All the LMGRD and ADSKFLEX
>>processes were shut down. I completely deleted the flexlm directory and
>>let adskflex re-create it, no joy.
>>Bill
>>jerry milana wrote:
>>>Bill,
>>>First, make sure there are no instances of LMGRD ot ADSKFLEX running on
> your
>>>server.
>>>Now make a copy of the folder c:\flexlm (just in case)
>>>Then delete the folder c:\flexlm
>>>Now reboot
>>>If everything begins to work again, you had a stale lock file.
>>>Jerry Milana,
>>>news:3E45ADA1.8060405@bellsouth.net...
>>>>I'm having a problem, the previously running License manager has
>>>>suddenly quit working. The service attempts to start up but fails to
>>>>complete startup. It appears to be starting hundreds of copies of
>>>>ADSKFLEX.EXE. The server slows to a crawl (since there are hundreds of
>>>>copies of ADSKFLEX.exe) and I have no choice but to kill the License
>>>>manager service which stops creating processes, all the copies of
>>>>adskflex die and everything comes back to life.
>>>>I installed 2 new Microsoft hotfixes 810847 and 811630 on a Win2k
>>>>server, other than that I have made no changes to the server that I can
>>>>recall. There is no uninstall for either of these, so I don't
>>>>positively know that they are the culprit. They don't appear to affect
>>>>anything that ACAD should be using...
>>>>I've tried re-installing license manager, but the symptoms persist. I
>>>>tried turning on logging and get the following: (I've included only the
>>>>start of the file, it goes on the same way over and over again).
>>>>Any help over the weekend would be appreciated, otherwise I'll be
>>>>rattling ACAD's cages first thing in the morning Monday when our CAD
>>>>operators can't work.
>>>>Thanks,
>>>>Bill
>>>>------------- Logfile
>>>>19:01:37 (lmgrd) -----------------------------------------------
>>>>19:01:37 (lmgrd) Please Note:
>>>>19:01:37 (lmgrd)
>>>>19:01:37 (lmgrd) This log is intended for debug purposes only.
>>>>19:01:37 (lmgrd) There are many details in licensing policies
>>>>19:01:37 (lmgrd) that are not reported in the information logged
>>>>19:01:37 (lmgrd) here, so if you use this log file for any kind
>>>>19:01:37 (lmgrd) of usage reporting you will generally produce
>>>>19:01:37 (lmgrd) incorrect results.
>>>>19:01:37 (lmgrd)
>>>>19:01:37 (lmgrd)
>>>>19:01:37 (lmgrd)
>>>>19:01:37 (lmgrd) Detecting other lmgrd processes...
>>>>19:01:37 (lmgrd) FLEXlm (v7.1f) started on GENGHIS (IBM PC) (2/8/2003)
>>>>19:01:37 (lmgrd) FLEXlm Copyright 1988-2000, Globetrotter Software, Inc.
>>>>19:01:37 (lmgrd) US Patents 5,390,297 and 5,671,412.
>>>>19:01:37 (lmgrd) World Wide Web: http://www.globetrotter.com
>>>>19:01:37 (lmgrd) License file(s): C:\Program Files\Autodesk License
>>>>Manager\License\2002.lic
>>>>19:01:37 (lmgrd) lmgrd tcp-port 27010
>>>>19:01:37 (lmgrd) Starting vendor daemons ...
>>>>19:01:37 (lmgrd) Starting vendor daemon at port 2080
>>>>19:01:37 (lmgrd) Started adskflex (pid 2388)
>>>>19:01:37 (lmgrd) license daemon: lost all connections
>>>>19:01:37 (lmgrd) This is an internal error. lmgrd will now
>>>>19:01:37 (lmgrd) attempt to re-establish contact with other daemons.
>>>>19:01:37 (lmgrd) Started adskflex (pid 1908)
>>>>19:01:37 (lmgrd) Started adskflex (pid 2932)
>>>>19:01:37 (lmgrd) Started adskflex (pid 2536)
>>>>19:01:37 (lmgrd) Started adskflex (pid 676)
>>>>19:01:37 (lmgrd) Started adskflex (pid 2528)
>>>>19:01:37 (lmgrd) Started adskflex (pid 2520)
>>>>19:01:37 (adskflex) cannot establish lock - exiting (file:
>>>>C:\flexlm\adskflex, errno: 13)
>>>>19:01:37 (lmgrd) Started adskflex (pid 2516)
>>>>19:01:37 (lmgrd) Started adskflex (pid 2424)
>>>>19:01:38 (lmgrd) Starting vendor daemons ...
>>>>19:01:38 (lmgrd) Starting vendor daemon at port 2080
>>>>19:01:38 (adskflex) Server started on GENGHIS for: 41100ACD_2002_0F
>>>>19:01:38 (adskflex) cannot establish lock - exiting (file:
>>>>19:01:38 (lmgrd) Started adskflex (pid 2452)
>>>>19:01:38 (lmgrd) license daemon: lost all connections
>>>>19:01:38 (lmgrd) This is an internal error. lmgrd will now
>>>>19:01:38 (lmgrd) attempt to re-establish contact with other daemons.
>>>>19:01:38 (lmgrd) Started adskflex (pid 2444)
>>>>19:01:38 (lmgrd) MULTIPLE "adskflex" servers running.
>>>>19:01:38 (lmgrd) Please kill, and run lmreread
>>>>19:01:38 (lmgrd)
>>>>19:01:38 (lmgrd) This error probably results from either:
>>>>19:01:38 (lmgrd) 1. Another copy of lmgrd running
>>>>19:01:38 (lmgrd) 2. A prior lmgrd was killed with "kill -9"
>>>>19:01:38 (lmgrd) (which would leave the vendor daemon running)
>>>>19:01:38 (lmgrd) To correct this, do a "ps -ax | grep adskflex"
>>>>19:01:38 (lmgrd) (or equivalent "ps" command)
>>>>19:01:38 (lmgrd) and kill the "adskflex" process
>>>>19:01:38 (lmgrd)
>>>>19:01:38 (lmgrd) Started adskflex (pid 2428)
>>>>19:01:38 (lmgrd)
>>>>19:01:38 (lmgrd)
>>>>19:01:38 (lmgrd) Started adskflex (pid 2376)
>>>>19:01:38 (lmgrd) Started adskflex (pid 2988)
>>>>19:01:38 (lmgrd) Started adskflex (pid 2996)
>>>>19:01:38 (lmgrd) Started adskflex (pid 2400)
>>>>19:01:38 (lmgrd) Started adskflex (pid 3048)
>>>>19:01:38 (adskflex) Vendor daemon can't talk to lmgrd ()
>>>>19:01:38 (lmgrd)
>>>>19:01:38 (lmgrd)
>>>>19:01:38 (lmgrd) Started adskflex (pid 3056)
>>>>19:01:38 (lmgrd)
>>>>19:01:38 (lmgrd)
