Have you tried this variable yet on the client PC?
Environment system variable: ADSKFLEX_LICENSE_FILE
Value: @PC-L
Best Regards, Jimmy Bergmark
CAD and Database Developer Manager at www.pharmadule-emtunga.com
Take a look at
JTB FlexReport (FLEXlm report tool) - www.jtbworld.com/jtbflexreport
SmartPurger (Purges automatically) - www.jtbworld.com/?/smartpurger.htm
or download some freeware at www.jtbworld.com
More on AutoCAD 2005;
www.jtbworld.com/autocad2005.htm
"0800reaper" wrote in message
news:19865643.1080656356011.JavaMail.jive@jiveforum2.autodesk.com...
> We are running Inventor 7 Series with an 20 Clients Network License
> FLEXlm is Installed and runs, but these log messages are strange:
> 12:16:22 (adskflex) Server started on PC-L for: 43500INVBUN_7_0F
> 12:18:14 (adskflex) Checkin failed feature "43500INVBUN_7_0F": ifwntuser
PC-L PC-L
> 12:18:14 (adskflex) ""
> 12:39:14 (adskflex) Checkin failed feature "43500INVBUN_7_0F": ifwntuser
PC-L PC-L
> 12:39:14 (adskflex) ""
> But the License-File seems OK:
> Vendor daemon status (on PC-L):
> adskflex: UP v8.3
> Feature usage info:
> Users of 43500INVBUN_7_0F: (Total of 20 licenses issued; Total of 0
licenses in use)
> When starting Inventor the "License Finder" popup comes up after a while.
I specify the server, it says OK and disappers. After some minutes, error
"1.5.-16" appears. Inventor not even starts. FLEXlm Error -16 means "Cannot
read data from license server", this could be everything.
> I tried all kinds of settings and environment Variabels but Inventor not
even starts on the machine which is running the License Manager. It's not an
network Issue nor the server is Firewalled or protected by an Virus scanner,
both TCP and UDP protocol are giving the same error code. Additional the
Server is online without any proxy, there is just an outgoing firewall. i
think, che Problem cannot be in the client side.
> Whats the Problem?
> Thanks in advance
> Thomas
> PS: I don't have access to the server all the time because it's an
customers server.
