Installation & Licensing
License Manager Config Error
13 REPLIES 13
Message 1 of 14
1081 Views, 13 Replies
I am creating a sigle server networked license in a 32bit windows for autoCAD 2008
I am getting this server status message:
Status
Flexible License Manager status on Thu 12/20/2007 12:53
[Detecting lmgrd processes...]
License server status: @PJLTWSERVER
License file(s) on PJLTWSERVER: C:\Program Files\Autodesk Network License Manager\ACD2008enlicense.lic:
lmgrd is not running: Cannot connect to license server system.
The license server manager (lmgrd) has not been started yet,
the wrong port@host or license file is being used, or the
port or hostname in the license file has been changed.
Server name: PJLTWSERVER
License path: @PJLTWSERVER;
FLEXnet Licensing error:-15,570
For further information, refer to the FLEXnet Licensing End User Guide,
available at "www.macrovision.com".
Help??
13 REPLIES 13
Message 2 of 14
mahahaavaahava
after you configured it, did you either boot the server or in the LMTOOLS-program go to Start/Stop/Reread and press Start Server? The message you get looks like you forgot to start it...
/Petri
Message 3 of 14
In th LMTOOLS- I did start the server. It said the server was started. Any other suggestions?
Message 4 of 14
mahahaavaahava
OK,
check for me once more that you have all 3 things configured correctly on the Configure Services Tab (see JPG). If and when this is the case, open the logfile and paste the relevant part of the Service loading-sequence here.(Start with:
3:03:21 (lmgrd) pid 5440
3:03:21 (lmgrd) Detecting other license server manager (lmgrd) processes...
3:03:21 (lmgrd) Done rereading
3:03:21 (lmgrd) FLEXnet Licensing (v11.4.0.0 build 31341) started on dev1 (IBM PC) (12/21/2007)
and all the way to either error or Server Started...
/Petri
Message 5 of 14
I'm having the same problem while trying to add a 2008 license to my 2005 license. Here is my log file:
13:23:57 (lmgrd) pid 5036
13:23:57 (lmgrd) Detecting other license server manager (lmgrd) processes...
13:23:58 (lmgrd) Done rereading
13:23:58 (lmgrd) FLEXnet Licensing (v11.4.0.0 build 31341) started on Fs02 (IBM PC) (1/23/2008)
13:23:58 (lmgrd) Copyright (c) 1988-2006 Macrovision Europe Ltd. and/or Macrovision Corporation. All Rights Reserved.
13:23:58 (lmgrd) US Patents 5,390,297 and 5,671,412.
13:23:58 (lmgrd) World Wide Web: http://www.macrovision.com
13:23:58 (lmgrd) License file(s): D:\Operations\Company Shared Folders\Autocad\ADT Network Version\License\ARCHDESK2005Fs02.lic
13:23:58 (lmgrd) lmgrd tcp-port 27000
13:23:58 (lmgrd) Starting vendor daemons ...
13:23:58 (lmgrd) Starting vendor daemon at port 2080
13:23:58 (lmgrd) Using vendor daemon port 2080 specified in license file
13:23:58 (adskflex) FLEXnet Licensing version v10.8.0 build 18869
13:23:58 (adskflex) lmgrd version 11.4, adskflex version 10.8
13:23:58 (adskflex) Server started on Fs02 for: 46700ARCHDESK_2005_0F
13:23:58 (adskflex) 54800REVSU_2008_0F PLIST
13:24:08 (adskflex) Vendor daemon can't talk to lmgrd (Cannot read data from license server system. (-16,287))
It looks like the 2005 license is doing fine, but something's wrong with the 2008 section.
Message 6 of 14
mahahaavaahava
seems to me you've created 2 services with LMTOOLS, one for the 2005 and one for the 2008? The correct way is to combine the Licensefiles and just run one process. Here's the "How-To":
http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=8057761&linkID=9240617
Try this and let me know how it went.
/Petri
Message 7 of 14
I only have 1 service. I followed that how-to to get as far as I did, but it's not working. I tried reinstalling the License Manager, but same result.
Message 8 of 14
mahahaavaahava
check the licensefile to see that the very long line after
NCREMENT PLIST adskflex 1.000 permanent 1 \
VENDOR_STRING
isn't wordwrapped. The whole Increment statement should be on one line. The \ character is a "licensefile" -hyphen and each line except the last one should end ..... \
/Petri
Message 9 of 14
Each line except the last one does end with a \ for each increment statement. No word wrapping
Message 10 of 14
mahahaavaahava
Howabout if you open both original Licensefiles, are the beginningparts before the Inrement identical?
This part:
SERVER servername 0123456789ab
USE_SERVER
VENDOR adskflex port=2080
/Petri
Message 11 of 14
Yes, they are identical.
Message 12 of 14
mahahaavaahava
OK,
what happens if you try running just the newer licensefile?
/Petri
Message 13 of 14
That worked so I pasted the 2005 license at the end of it and that worked too! Maybe the 2005 license had to be after the 2008 license? I have no idea. In any case, it works now. Thanks so much for your help!
Message 14 of 14
mahahaavaahava
Great!
Administrator Productivity
