I have been having some licensing issues and it seems like I am out of licenses. How would I go about solving this issue?
I have been getting the Licensing Error [-4.132.0] PDSU 2013. I attached the status enquiry for reference.
Solved by pendean. Go to Solution.
looks like you have 1 Prdss, 1 Prdsu and both are being used
DarrenP
Can I obtain more license seats somehow? I have not had this issue before then then all of a sudden this month I am out of licenses? How does that happen?
previous version use will consume more licenses
DarrenP
if running at the same time as 2013
DarrenP
if your users are running multiple versions at the same time nothing is stopping them from grabbing multiple licenses this is by design
you can create an options file to stop certain users from grabbing a previous version license
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=7459915&linkID=9240617
DarrenP
not unless you buy more
DarrenP
