Well i went to use Max today and i got this i reinstalled nothing helped…
any suggestions ?? ?
I would uninstall 3DS Max 2010 and reinstall it.
The Error 41 indicates that the ProductInformation.pit file maybe missing.
Can you upload the ProductInformation.pit file to this post?
It should be located here:
Windows Vista/Windows 7
C:\ProgramData\Autodesk\Adlm
XP
C:\Documents and Settings\All Users\Application Data\Autodesk\ADLM
Theirs no Autodesk folder and i just finished reinstalling it.
i haven't even activated it yet
Can you check out this post?
I read that I was supposed to delete it, to get rid of error 5, I did and now it is error 41, I tried using the installer but it does nothing! HELP!
Hi!
I've got this same problem and in the C:\ProgramData\Autodesk\Adlm folder, I have the file 'ProductInformation.pit' but error 41 is still here and I can't use Max 😕
Also, it crashes each time I try to insert the license number! I've reinstalled it 3 times, help!
