• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    Distinguished Contributor
    License Error [-15.570.10035]
    5894 Views, 20 Replies
    06-28-2010 05:32 AM
    Hi All
    Got into work today and am getting errors on 2 of my workstations, which will not retrieve licenses, and give me error       [-15.570.10035]
    I have 5 XP 64 Bit Machines, of which 3 have no issues connecting and retrieving a license.
    1 of the workstations I got to work by specifiying the license file rather then license server, But when I restart I need to put this information in again, and it will continue giving me the error if i try and specify license server.
    The other workstation just will not retrieve a licence file at all. I can ping the server from both workstations without an issue, and am able to get to the shared folder the license file sits in on the server.
    IPV6 is not installed on the clients or the server.
    I have tried removing the CAS file and recreating it with no results.
    Any other suggestions I could try?
    Please use plain text.
    TravisNave
    Re: License Error [-15.570.10035]
    06-28-2010 10:35 AM in reply to: BrettMOD
    Create two system environment variables in the Windows System Properties > Advanced tab.
    The first one should be named ADSKFLEX_LICENSE_FILE with the value of @servername.  Servername is the hostname of your server.
    The second should be named FLEXLM_TIMEOUT with the value of 1000000 (one-million.)
    That should be a good start.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Active Member
    12-20-2012 05:57 AM in reply to: BrettMOD
    I keep getting this message with one user running AutoCad 2013.
    Any fixes for this?
    DarrenP
    12-20-2012 06:10 AM in reply to: gtbaker
    did you read the above thread for a solution to try?
    Active Member
    12-20-2012 06:53 AM in reply to: DarrenP
    Yes and no luck.
    DarrenP
    12-20-2012 06:57 AM in reply to: gtbaker
    have you checked the license manager to see if its actually running?
    Active Member
    12-20-2012 07:12 AM in reply to: DarrenP
    The license service on the server is running and working.  Other people can run 2013 with no issues...it's just this one user.
    Would I need to re-install?
    ***I should add this issue is new.  He was running 2013 fine up until a couple of days ago.  I went through the Windows updates and removed any newly install updates.
    DarrenP
    12-20-2012 07:56 AM in reply to: gtbaker
    can they ping the license server by name?
    DarrenP
    12-20-2012 07:56 AM in reply to: DarrenP
    also try turning off the firewall on that machine if possible
    Active Member
    12-20-2012 08:07 AM in reply to: DarrenP
    They can see the same shared drives from the server and the firewall is controlled from a Sonicwall router.  The two users are at a remote location.  Like I said one can the other cannot.  All users at the server location can.
    When I get back I will try the ping test.
