Installation & Licensing
Distinguished Contributor
BrettCaldeira
Message 1 of 21 (7,250 Views)
License Error [-15.570.10035]
7250 Views, 20 Replies
06-28-2010 05:32 AM
Hi All
Got into work today and am getting errors on 2 of my workstations, which will not retrieve licenses, and give me error       [-15.570.10035]
I have 5 XP 64 Bit Machines, of which 3 have no issues connecting and retrieving a license.
1 of the workstations I got to work by specifiying the license file rather then license server, But when I restart I need to put this information in again, and it will continue giving me the error if i try and specify license server.
The other workstation just will not retrieve a licence file at all. I can ping the server from both workstations without an issue, and am able to get to the shared folder the license file sits in on the server.
IPV6 is not installed on the clients or the server.
I have tried removing the CAS file and recreating it with no results.
Any other suggestions I could try?
TravisNave
Message 2 of 21 (7,236 Views)
Re: License Error [-15.570.10035]
06-28-2010 10:35 AM in reply to: BrettCaldeira
Create two system environment variables in the Windows System Properties > Advanced tab.
The first one should be named ADSKFLEX_LICENSE_FILE with the value of @servername.  Servername is the hostname of your server.
The second should be named FLEXLM_TIMEOUT with the value of 1000000 (one-million.)
That should be a good start.
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
Active Member
gtbaker
Message 3 of 21 (2,210 Views)
12-20-2012 05:57 AM in reply to: BrettCaldeira
I keep getting this message with one user running AutoCad 2013.
Any fixes for this?
DarrenP
Message 4 of 21 (2,205 Views)
12-20-2012 06:10 AM in reply to: gtbaker
did you read the above thread for a solution to try?
Active Member
gtbaker
Message 5 of 21 (2,199 Views)
12-20-2012 06:53 AM in reply to: DarrenP
Yes and no luck.
DarrenP
Message 6 of 21 (2,194 Views)
12-20-2012 06:57 AM in reply to: gtbaker
have you checked the license manager to see if its actually running?
Active Member
gtbaker
Message 7 of 21 (2,189 Views)
12-20-2012 07:12 AM in reply to: DarrenP
The license service on the server is running and working.  Other people can run 2013 with no issues...it's just this one user.
Would I need to re-install?
***I should add this issue is new.  He was running 2013 fine up until a couple of days ago.  I went through the Windows updates and removed any newly install updates.
DarrenP
Message 8 of 21 (2,178 Views)
12-20-2012 07:56 AM in reply to: gtbaker
can they ping the license server by name?
DarrenP
Message 9 of 21 (2,176 Views)
12-20-2012 07:56 AM in reply to: DarrenP
also try turning off the firewall on that machine if possible
Active Member
gtbaker
Message 10 of 21 (2,170 Views)
12-20-2012 08:07 AM in reply to: DarrenP
They can see the same shared drives from the server and the firewall is controlled from a Sonicwall router.  The two users are at a remote location.  Like I said one can the other cannot.  All users at the server location can.
When I get back I will try the ping test.
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
