Installation & Licensing
*Nickels, Mark
Message 1 of 3 (187 Views)
License Configuration Switching Utility
187 Views, 2 Replies
09-09-2001 11:41 PM
I found the following on the Autodesk web site. Is this available on the US
version or only on the International version. If it is the International
version only - It should be stated in the doc. (Tech Doc TS66251).
I copied part of the content below.
Applies to: AutoCAD® 2002
Published Date: 08/28/2001
Issue
You want to switch from a network license to a stand-alone license so you
can work remotely.
Solution
In AutoCAD® 2002, Autodesk has introduced the License Configuration
Switching utility. This utility allows for switching between network and
stand-alone usage. That is, network license users can acquire a stand-alone
license in order to work remotely. The switcher does not decrease the
FLEXlm® license count. Separate C-Dilla-based stand-alone licenses must be
purchased and available to take advantage of this functionality.
Planning
The license switcher does not "borrow" a network license from the FLEXlm
server, therefore stand-alone licenses must be available for use. When
planning your deployment of AutoCAD 2002, you should ensure that you have
purchased the correct number of network and stand-alone licenses for your
anticipated needs.
Example:
You have 50 users of AutoCAD 2002. Five of your workstations are portable
computers for use when disconnected from the network. If you require clients
to use Network licenses when connected to the network you must purchase the
following licenses if you know that all users will be connected to the
network at the same time and require a FLEXlm license:
50 network licenses
5 stand-alone licenses
*martin, jason
Message 2 of 3 (187 Views)
Re: License Configuration Switching Utility
09-10-2001 01:01 AM in reply to: *Nickels, Mark
Mark -
The license configuration switcher is international only.
I agree it should be in the doc as well as the help file.
jason martin
frankfurt-short-bruza
"Mark Nickels" wrote in message
news:4CDB3F7E57F6258CA68D134F43E6316C@in.WebX.maYIadrTaRb...
> Issue
> can work remotely.
> Solution
> Planning
> anticipated needs.
> Example:
> 50 network licenses
*Support\, Autodesk
Message 3 of 3 (187 Views)
Re:
09-11-2001 07:24 PM in reply to: *Nickels, Mark
The doc is in the process of being updated.
Simon Gillis
Analyst
DPG Product Support EMEA
Autodesk WW Support & Services
"jason martin" wrote in message
news:AF592BC8F7A0546899B88E11692F3ABF@in.WebX.maYIadrTaRb...
> Mark -
> jason martin
the US
International
> > Issue
you
> > can work remotely.
> > Solution
stand-alone
be
> > Planning
have
your
> > anticipated needs.
> > Example:
portable
clients
the
> > 50 network licenses
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
