Installation & Licensing
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Licence server to another domain
- Highlight
- Email to a Friend
Customer has moved licence server and user workstations to new domain. The user profiles are still on the old domain. Now Autodesk Products (AutoCAD and Inventor) are asking the licence server every time when started....
What could cause this..?
mako
Re: Licence server to another domain
- Highlight
- Email to a Friend
Compare the MAC address in the license file with the server to see if they match. If they're different, you'll need to obtain a new license file from Autodesk.
Support Specialist
Synergis Technologies
If this resolve your issue/question, give Kudos or Accept as Solution...
- Highlight
- Email to a Friend
Domain changes can sometimes cause some weird cache issues. Make sure that the NLM is running on the server still and handing out licenses.
The clients need to be able to PING the server and obtain the correct IPv4 address. Then verify connectivity thru the firewall (as domain changes affects firewall settings) to make sure you can get to http://servername:2080 and http://servername:27000 in Internet Explorer.
And then, make sure the ADSKFLEX_LICENSE_FILE is set.
My Expert Contributions to the Discussion Groups: FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
