I can not resize acceptance window when activating licence so can not reach accept and continue buttons.
You should probably start here:
Also, phone support is handled thru a value-added Reseller.
Hi Gerry,
Just took a look and can confirm that your 2013 license was upgraded to the 2014 per an expired contract, which would explain the error.
I'll send you a Private Message with the 2014 license info + download links. Alternatively you can continue using the 2013 license as long as you do not activate the 2014 one, however a manually generated activation code would be required.
To find self-service solutions or reach us via Chat for Activation and Licensing Help:
Visit http://knowledge.autodesk.com/contactus
Select “Activation & Registration” or “License Management”
Select appropriate subtopics from the pull-down menus.
Select “I Still Need Help” if you need personal assistance.
