• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    Member
    Accepted Solution
    Licence Error 43
    378 Views, 6 Replies
    04-20-2012 03:01 AM
    I'm having trouble with Ecotect Analysis 2011's licence. The image show the error message. I inserted the student licence that I had received from the autodesk students site where I downloaded this software. Also when I try to use Licence Transfer Utility the error is the same.
    Someone can help me?
    Edited by
    Discussion_Admin
    Please use plain text.
    camilo.lemos
    Re: Licence Error 43
    04-20-2012 04:23 AM in reply to: rosamaria.demattia
    Hi Rosamaria,
    It appears that your your product has not been registered and activated yet. That may be why you are getting these error messages.
    Please, go to http://registeronce.autodesk.com to complete your product registration and activation procedures.
    Let us know if that solves the issue:smileyhappy:
    Camilo Lemos
    AutodeskHelp | Community Manager
    TW | PI | YT | BLOG
    Member
    04-20-2012 06:50 AM in reply to: camilo.lemos
    Hi Camilo,
    thank you! I followed your suggestion, completing the regitration online but the error is the same (photo). Can you help me again?
    Edited by
    Discussion_Admin
    Customer Service
    Angelo.A
    04-20-2012 10:15 AM in reply to: rosamaria.demattia
    Hi Rosamaria,
    I sent you a message earlier, please reply at your earliest convenience, thanks,
    Angelo Aramayo
    Front Desk Representative
    Autodesk, Inc.
    Customer Service
    Angelo.A
    04-24-2012 08:21 AM in reply to: rosamaria.demattia
    Hi Rosamaria,
    I'm just doing a follow up on the message I sent yesterday, please reply at your earliest convenience, thanks,
    Angelo Aramayo
    Autodesk, Inc.
    Product Support
    alan.quinn
    05-07-2012 06:17 AM in reply to: Angelo.A
    Since it sounds like the application is not installed correctly I suggest doing a clean uninstall and re-install. Please see the below link for additional details.How to remove all Autodesk products from a Windows system: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617 Here's a good Forum Post on install issues: http://forums.autodesk.com/t5/Autodesk-Ecotect-Analysis/problem-with-licensing-Ecotect/td-p/3413747 Hope this helps and let me know if you have additional questions or comments. Thanks for posting,
    Alan Quinn
    Support Specialist
    Product Support
    Autodesk, Inc.
    Member
    05-08-2012 08:48 AM in reply to: alan.quinn
    thanks! I've solved the problem
