Installation & Licensing
Licence Error 43
6 REPLIES 6
rosamaria.demattia
1438 Views, 6 Replies
Licence Error 43
I'm having trouble with Ecotect Analysis 2011's licence. The image show the error message. I inserted the student licence that I had received from the autodesk students site where I downloaded this software. Also when I try to use Licence Transfer Utility the error is the same.
Someone can help me?
Edited by
Discussion_Admin
Tags (2)
6 REPLIES 6
Hi Rosamaria,
It appears that your your product has not been registered and activated yet. That may be why you are getting these error messages.
Please, go to http://registeronce.autodesk.com to complete your product registration and activation procedures.
Let us know if that solves the issue:)
Camilo Lemos
Hi Camilo,
thank you! I followed your suggestion, completing the regitration online but the error is the same (photo). Can you help me again?
Edited by
Discussion_Admin
Hi Rosamaria,
I sent you a message earlier, please reply at your earliest convenience, thanks,
Angelo Aramayo
Front Desk Representative
Autodesk, Inc.
Hi Rosamaria,
I'm just doing a follow up on the message I sent yesterday, please reply at your earliest convenience, thanks,
Angelo Aramayo
Autodesk, Inc.
alan.quinn
in reply to: Angelo.A
Since it sounds like the application is not installed correctly I suggest doing a clean uninstall and re-install. Please see the below link for additional details.How to remove all Autodesk products from a Windows system: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617 Here's a good Forum Post on install issues: http://forums.autodesk.com/t5/Autodesk-Ecotect-Analysis/problem-with-licensing-Ecotect/td-p/3413747 Hope this helps and let me know if you have additional questions or comments. Thanks for posting,
thanks! I've solved the problem
Administrator Productivity
