Hi everybody, so I have a problem with my 3ds max that I can't seem to figure out.
I used to have 3DS Max 2010 insalled on my pc, but due to a recnet HDD failure I lost everything. So i got a new hard drive and installed it to there, tried to download my licence online with the transfer utility, and it won't work, or even conenct for that matter. Does anyone know how to fix this? It's driving me insane, and trying to navigate this website is making me more frustrated...
"A License error has occurred. Contact your technical support representative for assistance.
To help detemine the nature of the problem the error code is: 110"
Hi Bob,
The License Transfer Utility can be very problematic. Have you tried re-activating your software through the software / via the standard online process?
Sure thing Bob,
There is no need to utilize the License Transfer Utility system. After you have re-installed the software on your machine, upon starting it up you should receive either the option to Activate, or Run the Product (and continue using as a trial). If you select Activate, you will be prompted to to complete the online activation process. Please find the following like for your reference.
3ds Max Post Install Setup - LINK
Does this help?
Sometimes this error also comes because of missing licensing files. You may want to uninstall and install again.
Also, make sure that you have write permission on the ProgramData\Autodesk folder.
Hope this helps.
I know how to fix it
first,you have to open notepad and type this thing
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\*\shell\runas]
@="Take Ownership"
"NoWorkingDirectory"=""
[HKEY_CLASSES_ROOT\*\shell\runas\command]
@="cmd.exe /c takeown /f \"%1\" && icacls \"%1\" /grant administrators:F"
"IsolatedCommand"="cmd.exe /c takeown /f \"%1\" && icacls \"%1\" /grant administrators:F"
[HKEY_CLASSES_ROOT\Directory\shell\runas]
@="Take Ownership"
[HKEY_CLASSES_ROOT\Directory\shell\runas\command]
@="cmd.exe /c takeown /f \"%1\" /r /d y && icacls \"%1\" /grant administrators:F /t"
"IsolatedCommand"="cmd.exe /c takeown /f \"%1\" /r /d y && icacls \"%1\" /grant administrators:F /t"
then save it name Take Ownership.reg
then click on it and click Yes
Now you can Unlock folder that have key pic on it
go to C:\ProgramData
and right click on Autodesk select Take Ownership
then refesh.Now you can see the key pic disappear
do this the same with FLEXNet Folder (same location)
Install Program again
Good luck 🙂
I have a building design suite ultimate 2014 for PC. I heard I can use same key for Mac version, but I am getting this message. Is PC serial working for Mac version?
thanks
