We use AutoCAD on a NT network. When I look at the "drawing properties" and go to the "statistics" tab the "last saved by" area is blank. If I type loginname on the command line and hit enter the persons last name comes up and then if you save the drawing after this and look at the "last saved by" is correct. This will work as long as you keep that session of AutoCAD open. Do we need to have that loginname in a startup file for AutoCAD?
