Installation & Licensing
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Laptop copy of Inventor 2009 Pro not retaining activation .
- Highlight
- Email to a Friend
We have a copy of Inventor 2009 Pro installed and activated on a Win XP X64 desktop with no issues. Put an additional "away from usual work location" installation on my boss' Win 7 laptop and it indicated that it had activated successfully. However, it would seem that it is not retaining that activation as it has periodically resubmitted activation requests until recently when it is now infoming us that we have reached our activation limit. Can anyone offer any ideas as to why this is happening, suggestions, fixes, etc? Thanks in advance.
Gary
Re: Laptop copy of Inventor 2009 Pro not retaining activation .
- Highlight
- Email to a Friend
Somebody? Anybody? Any help would be really appreciated.
Thanks.
- Highlight
- Email to a Friend
Hello Gary,
I'm not 100% that this will work, but can you rename the following file by adding a .bak extension at the end of the filename.
Windows XP
C:\Documents and Settings\All Users\Application Data\FLEXnet\adskflex_*_tsf.data
Vista/Windows 7
C:\ProgramData\FLEXnet\adskflex_*_tsf.data
When you restart Inventor and it should automatically re-register and as a result a new adskflex_*_tsf.data file will be created and it will start up as expected.
I also wanted to point out that Inventor 2009 is not officially supported to run in Windows 7, and as such functionality may or may not be impaired.
- Highlight
- Email to a Friend
Hi Philip,
I will give it a try and get back to you.
One question though: Will I need to contact Autodesk first and have them reset the activation limit after I make the suggested change but before I restart Inventor?
Gary
- Highlight
- Email to a Friend
Sounds good and yes, if you're still receiving the activation limit reached error, please either send me a Private Message (click on my philip.s profile name and then "Send this user a private message") with your serial number + request code, or contact our License Assistance team for an activation code.
- Highlight
- Email to a Friend
Looked in C:\ProgramData and found no FLEXnet directory. Did a drive-wide search for adskflex_*_tsf.data and there were no matches.
- Highlight
- Email to a Friend
My apologies Gary, as that is the location for 2010-2013 products.
For 2009 the adskflex_*_tsf.data file should be in the following:
XP
C:\Documents and Settings\All Users\Application Data\Autodesk\Software Licenses
Vista/Windows 7
C:\Users\All Users\Autodesk\Software Licenses
If that doesn't work, you may want to consider running the software in XP / Compatability Mode to see if it clears up the issue (as previously mentioned, Inventor 2009 is not supported on Windows 7).
Hope that helps!
- Highlight
- Email to a Friend
Philip,
There are only two files in C:\Users\All Users\Autodesk\Software Licenses. Neither match the adskflex_*_tsf.data mask that you provided. They are named B54A5000.dat and B55DF000.dat. Please advise...
Gary
- Highlight
- Email to a Friend
- Highlight
- Email to a Friend
Philip,
Deleted license files, restarted inventor and it seemed to recognize that the license files were absent thereby initiating another activation dialog. As already expected, it responded with the "activation limit reached" error message. Per your earlier instructions, I have already sent you a private message containing the serial and request code. Thanks in advance for your time.
Gary
