• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Lab Environment With Multiple Users Having Issues With Windows 7
    302 Views, 4 Replies
    10-11-2011 02:36 PM
    We recently upgraded our CAD lab to Windows 7 and have come across some issues.  We have a multi user classroom.  Before W7 I would install the software using the local admin account, make the customizations I needed then copy the local admin profile to the default user profile.  The students would then get all the customizations I made when they log on.
    Windows 7 is very different in the way it handles profiles.  I have tried everything I can think of and still not all of the customizations, file paths, etc. are holding.  I've tried using sysprep, tried using Windows Enabler and tired a straight data copy.
    For instance, right now we can't run Inventor because the default profile didn't hold the location of the Undo directory.  Since these things are per-user changes and we have hundreds of students it is impossible to change them for every user.
    Is anyone else running the Education Master Suite 2010 and/or 2012 on Windows 7 in a lab environment like this?  Has anyone had these issues and found a way to deal with them?
    Please use plain text.
    Product Support
    Re: Lab Environment With Multiple Users Having Issues With Windows 7
    10-13-2011 12:17 PM in reply to: achapin
    We get this one a lot for Inventor.  Please check out this post:
    http://forums.autodesk.com/t5/Autodesk-Inventor/Imaging-Inventor-and-Current-Undo-Folder/td-p/276233...
    David Lau
    Product Support | Up and Ready Blog | If my reply was helpful, please Kudo or Accept as Solution. :smileywink:
    My 5 Top Issues in the Discussion Groups
    1402 Error [Uninstall] | Faro doesn't install | adlmPITSetProductInformation Errors | Empty Tool bar in AutoCAD Mac | Win 7 Registry Limit
    10-13-2011 12:25 PM in reply to: achapin
    Thanks for the info, but the link only applies to XP.  I've been doing that very thing up until this year when we migrated to Windows 7.
    10-13-2011 01:47 PM in reply to: achapin
    A little more info...I need a way for these changes to be in place when the user sits down.  We have several hundred students and having them all run a command or xml file or regedit isn't feasable.  Additionally, our computers are frozen with Faronics DeepFreeze so any changes a user might make will revert overnight when the comptuers reboot.
    Product Support
    10-13-2011 01:52 PM in reply to: achapin
    I think you are just customizing Inventor with a non profile specific folder.  i.e. C:\InventorTemp.  You will  need to create a C:\InventorTemp folder on your Windows 7 computer.
    David Lau
