Installation & Licensing
*Catalucci, Jeff
Message 1 of 5 (126 Views)
LT98 and ADLM - Always have to reauthorize on powerdown
126 Views, 4 Replies
02-09-2000 06:00 PM
<<< Message <87spb1$ci833@adesknews2.autodesk.com> was originally posted to 'autodesk.autocadlt.98general' on Wed, 9 Feb 2000 17:22:38 -0500.>>>
I have a customer who is running the ADLM on an NT 4.0 w/SP3 server with the
following hardware. Every time he downs his server, he has to reauthorize
his LT98:
NIC (Mfr. & Model #)
- 3Com EtherLink XL (3C900)
driver version
- [El90x.sys] 2.12 (3/10/97)
Computer's manufacturer & model
- Dell PowerEdge 4200
SCSI or IDE
- SCSI (100%); no RAID
Protocol
- TCP/IP - It has a static IP address.
- The server has 1 NIC
- There have been no problems with the NIC
- The server does not utilize RAS
Here is an excerpt from the ADLM.LOG file from the last restart:
00-Jan-03 16:58:02: Autodesk License Manager - Copyright 1997 Elan Computer
Group, Inc.
00-Jan-03 16:58:02: ADLM 5.0.1c started on gamma (0adc0a04).
00-Jan-03 16:58:02: Vendor ID = 1a2ccac.
00-Jan-03 16:58:02: Default Hostcode = 1536 (03000) = ETHER+HISECURE.
00-Jan-03 16:58:02: PID = 97.
00-Jan-03 16:58:02: Port = 1422.
00-Jan-03 16:58:02: Log file = e:\adlm\LOG\ADLM.LOG.
00-Jan-03 16:58:02: Key path = e:\adlm\KEY.
00-Jan-03 16:58:02: Keyaccept = 310.
00-Jan-03 16:58:02: Resource file = .
00-Jan-03 16:58:02: Message level = 3.
00-Jan-03 16:58:02: Max log file size = 65536 bytes.
00-Jan-03 16:58:02: Initialization period = 100 seconds.
00-Jan-03 16:58:02: Peer registered: "gamma" 0adc0a04 0adc0a04 10.220.10.4
10.220.10.4.
00-Jan-03 16:58:04: Authorization failure; key e:\adlm\KEY\250.lic only
valid
for: gamma.
00-Jan-03 16:59:46: Sheridan@gamma [0]: Loaded key /adlm/key\250.lic 1
tokens
[MINIKEY].
00-Jan-03 16:59:46: Sheridan@gamma [2]: Load New/Modified Keys in
e:\adlm\KEY.
*Milana, Jerry
Message 2 of 5 (126 Views)
Re: LT98 and ADLM - Always have to reauthorize on powerdown
02-09-2000 06:49 PM in reply to: *Catalucci, Jeff
Jeff,
I'll bet that if you were to go into Control Panel and stop then restart the AdLM manually after a reboot it would have the same effect as
reauthorizing the license manager. If you try this, it will verify my suspicion of what your problem is.
What occurs is that some system-network adapter combinations result in a condition where the network adapter is slow to initialize. When AdLM
starts up it attempts to authenticate against the card before it is fully up, causing an authentication failure. When you enter a key code in AdLM
Admin or stop and start the the license manager, AdLM completes the authentication against the fully initialized adapter, resulting in
authentication success.
So, if my test proves me correct, the first thing you should do is obtain the latest driver for the network adapter from the manufacturer and apply
it. In many cases, this fixes the problem. If the problem persists, let me know.
Jerry Milana,
Autodesk Product Support
> his LT98:
> driver version
> SCSI or IDE
> Protocol
*Hartung, T.J.
Message 3 of 5 (126 Views)
Re:
03-13-2000 07:54 PM in reply to: *Catalucci, Jeff
I am having a similar problem. Whenever I reboot my server, the Adlm will
not issue a license. If I double click on the Adlm query and click on active
licenses the Adlm will issue licenses without a problem. Will the fix stated
below help me with my problem?
Jerry Milana wrote in message
news:38A2273D.26460322@autodesk.com...
> Jeff,
me know.
> Jerry Milana,
the
reauthorize
> > his LT98:
> > driver version
> > SCSI or IDE
> > Protocol
*Milana, Jerry
Message 4 of 5 (126 Views)
Re:
03-14-2000 03:48 PM in reply to: *Catalucci, Jeff
It should fix it. Updating the NIC driver does not always work. Some
computer/NIC combinations are just slow to initialize. The first thing you
should do is update the driver, if that does not work, post a message here
again.
Jerry Milana,
> > Jeff,
> me know.
> > Jerry Milana,
> the
> reauthorize
> > > his LT98:
> > > driver version
> > > SCSI or IDE
> > > Protocol
*Hartung, T.J.
Message 5 of 5 (126 Views)
Re:
03-15-2000 02:28 PM in reply to: *Catalucci, Jeff
I updated the NIC driver and still no luck. The NIC is a Hp DeskDirect
10/100TX PCI LAN adapter. The server is HP Netserver LH Pro
news:38CECFB6.3A7EDF3C@autodesk.com...
you
> again.
> Jerry Milana,
will
active
stated
> > > Jeff,
restart
a
fully
AdLM
obtain
apply
let
> > me know.
> > > Jerry Milana,
posted
with
> > the
> > reauthorize
> > > > his LT98:
> > > > driver version
> > > > SCSI or IDE
> > > > Protocol
You are not logged in.
Announcements
Need installation help?
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
