Gordon,
When using the Network Installation Wizard (NIW) to create your deployment
image, you will be able to enter just one serial number when creating the
deploy image. If you have all of the seats under a single serial number,
than you use just that single serial number when creating your deployment
image.
On the other hand, if you have multiple serial numbers for your standalone
seats, you will need to change the serial numbers accordingly for each of
your installs/activations. To use the NIW in this environment, with
standalone seats with multiple serial numbers, you can alter the serial
number either by; a) modifying the deploy image to create a unique deploy
image for each serial number, or b) by using a non-silent deploy and
modifying the serial number at install time at the client workstation.
Greg Suppes
Autodesk, Inc.
"Gordon Price" wrote in message
news:40881556$1_1@newsprd01...
> LT doesn't support network licensing. Also, each install requires a unique
> serial number and authorization (no more owning 5 licenses, but installing
> one license and auth code 5 times). But there is a network install wizard,
> which I would like to use. But how does one use it? Do you create 5
> different installs, one for each license, and make sure each install is
> identical? Can you create a single install that offers 5 different
licenses,
> and you have to make sure you choose a different one for each machine? The
> wizard suggests there is an easier way than going machine to machine doing
a
> traditional manual install, but I am not clear on what is the best way to
do
> it.
> Thanks,
> Gordon
