Installation & Licensing
247 Views, 5 Replies
LT 2012 LTU
We bought one standalone version of Autocad LT 2012. There are 3 users who need to use the program but don't work on the same time with it.
Can i use the LTU and install this version on 3 pc's and let the users transfer the license between them? It might be possible technically but is it allowed on licenseterms?
5 REPLIES 5
TravisNave
Yeah, you can attempt this but the LTU is not reliable. Eventually it will break and you will be left without a license.  You might consider upgrading to a full seat of AutoCAD and adding network activation to it.  That way they can all have AutoCAD installed and just share the single network license.  It's worth it.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
pendean
in reply to: TravisNave
It would be cheaper to buy (2) additional LT seats 🙂
TravisNave
in reply to: pendean
Haha!  True indeed.  Smiley Very Happy
Autodesk Forums:
Is LTU that buggy? I'll try if it works. When not w start thinking about more licenses
When the export fails i have to reactivate with autodesk?
TravisNave
No, I was exaggerating on the LTU.  It's actually much worse than my description.  And yes, when it fails, you will have to reactivate thru Autodesk.  Good luck!
Autodesk Forums:
Administrator Productivity
