Installation & Licensing
LMTools Services won't run automatically.
6 REPLIES 6
syed.dzulkarnain
6312 Views, 6 Replies
Hi all, i need help. I have a BDS Premium 2014 & BDS Ultimate 2014 network license running. Server is running on Windows Server 2008.
My Problem : The server is automatically restart at midnight for data backup procedure, but after restart, the LMTools Services won't run automatically. I have to Re-read license file every morning in order to get my applications to work.
My Effort : i already checked the 'Start Server at Power up' & 'use Services' at Config service tab but still did not work.
Kindly need your assistance on this.
many thanks.
SyedDzulkarnain
Tags (1)
6 REPLIES 6
Please check out step 3 here:
http://upandready.typepad.com/up_and_ready/2011/11/quick-start-setting-up-a-license-server.html
I would stop the server, delete the service and re-create it. I made some notes to do it via step 3.
David Lau
Hi, thanks for your reply.My method of doing is the same as the link you provided. Wll try to create a new services for this.many thanks.Smiley Happy
the issue is solved.what i did is i set the LMTOOLS as a startup services.Smiley Very Happy
I am glad you figured it out.  You can indeed set the service to startup via services.msc.
David Lau
thats what i did. it works for now.
Administrator Productivity
