Hi all, i need help. I have a BDS Premium 2014 & BDS Ultimate 2014 network license running. Server is running on Windows Server 2008.
My Problem : The server is automatically restart at midnight for data backup procedure, but after restart, the LMTools Services won't run automatically. I have to Re-read license file every morning in order to get my applications to work.
My Effort : i already checked the 'Start Server at Power up' & 'use Services' at Config service tab but still did not work.
Kindly need your assistance on this.
many thanks.
SyedDzulkarnain
Solved by syed.dzulkarnain. Go to Solution.
Please check out step 3 here:
http://upandready.typepad.com/up_and_ready/2011/11/quick-start-setting-up-a-license-server.html
I would stop the server, delete the service and re-create it. I made some notes to do it via step 3.
Hi, thanks for your reply.My method of doing is the same as the link you provided. Wll try to create a new services for this.many thanks.
the issue is solved.what i did is i set the LMTOOLS as a startup services.
I am glad you figured it out. You can indeed set the service to startup via services.msc.
