I've got networked licenses distributed among many servers. When performing a status inquiry of the licenses, the output stops and I can't see all the servers in our network. Is there a limitation in LMTOOLS on the number of lines of text that can be shown in status inguiry?
Seems to be an issue - here's a workaround...
Recommendation
To view the full active license status list, you can execute the Perform Status Enquiry command via Windows command-prompt, as follows:
For ease in analyzing, you can route the generated content into a text file (eg. output.txt) by using the following command : “> c:\output”
