Installation & Licensing
LMTOOLS Does Not See All Licenses In File
5 REPLIES 5
537 Views, 5 Replies
Only 1 user at a time is able to use NavisWorks 2014, although we have two licenses.
When I upload our license file at www.licenseparser.com I can see two seats.  Each has its own unique serial number (removed here for privacy):
Package Increments Matched
Seats Feature Feature Code Serial Number Issue Date Expiration
1Subscription Package: Autodesk NavisWorks Manage .167600NAVMAN_F*PastFuture
 Autodesk Navisworks Manage 201486166NAVMAN_2014_0F
 Autodesk Navisworks Manage 201386022NAVMAN_2013_0F
 Autodesk Navisworks Manage 201285839NAVMAN_2012_0F
 Autodesk Navisworks Manage 201185600NAVMAN_2011_0F
However, LMTOOLS does not appear to agree with that analysis.  Even after re-reading the license file and restarting services I still see the same thing
SERVER01: license server UP (MASTER) v11.5
Vendor daemon status (on SERVER01):
adskflex: UP v11.5
Feature usage info:
Users of 67600NAVMAN_F: (Total of 1 license issued; Total of 0 licenses in use)
Users of 86166NAVMAN_2014_0F: (Total of 1 license issued; Total of 0 licenses in use)
Users of 86022NAVMAN_2013_0F: (Total of 1 license issued; Total of 0 licenses in use)
Users of 85839NAVMAN_2012_0F: (Total of 1 license issued; Total of 0 licenses in use)
Users of 85600NAVMAN_2011_0F: (Total of 1 license issued; Total of 0 licenses in use)
Where do I go from here?  Thanks in advance for your help!
5 REPLIES 5
DarrenP
were both licenses generated the same day?
DarrenP
DarrenP
in reply to: DarrenP
the license parser should tell you that
DarrenP
Yep they were both generated the same day.  Through what witchcraft/wizardry did you know that?
TravisNave
I suspect not, since the status enquiry only shows one is available instead of 2.  You might need to get both seats regenerated and combined back into one file.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
in reply to: TravisNave
Happy to report that this is resolved.  AutoDesk provided a working license file.  Here is the LMTOOLS output now:
adskflex: UP v11.5
Feature usage info:
Users of 67600NAVMAN_F: (Total of 2 licenses issued; Total of 0 licenses in use)
Users of 71400NAVMAN_2010_0F: (Total of 2 licenses issued; Total of 0 licenses in use)
Users of 86166NAVMAN_2014_0F: (Total of 2 licenses issued; Total of 0 licenses in use)
Users of 86022NAVMAN_2013_0F: (Total of 2 licenses issued; Total of 0 licenses in use)
Users of 85839NAVMAN_2012_0F: (Total of 2 licenses issued; Total of 0 licenses in use)
Users of 85600NAVMAN_2011_0F: (Total of 2 licenses issued; Total of 0 licenses in use)
Administrator Productivity
