• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    Member
    Just Installed Inventor 2013...
    369 Views, 5 Replies
    01-26-2013 09:43 AM
    trying to put this in like 14 times, during install a window called"windows installer" pops up, with a really long list of coding or something, and it stops. my computer is brand new,  "samsung, amd quad-core a10-4600m apu 2.30Ghz, 8 gig ram, 750 gig hdd, 64 bit, windows 8, "windows experience index" gives this a 5.9. my old computer was a 3.6 but at least it works. I need this running yesterday! anyone what do i do, i tried to call, but they have no support for some reason?, when i called licensing they said try to put the software from my old computer to the new one on a flash, but of course it didnt work and now i have no software to finish my homework,  here is what it says...............
    Windows ® Installer. V 5.0.9200.16384
    msiexec /Option <Required Parameter> [Optional Parameter]
    Install Options
    </package | /i> <Product.msi>
    Installs or configures a product
    /a <Product.msi>
    Administrative install - Installs a product on the network
    /j<u|m> <Product.msi> [/t <Transform List>] [/g <Language ID>]
    Advertises a product - m to all users, u to current user
    </uninstall | /x> <Product.msi | ProductCode>
    Uninstalls the product
    Display Options
    /quiet
    Quiet mode, no user interaction
    /passive
    Unattended mode - progress bar only
    /q[n|b|r|f]
    Sets user interface level
    n - No UI
    b - Basic UI
    r - Reduced UI
    f - Full UI (default)
    /help
    Help information
    Restart Options
    /norestart
    Do not restart after the installation is complete
    /promptrestart
    Prompts the user for restart if necessary
    /forcerestart
    Always restart the computer after installation
    Logging Options
    /l[i|w|e|a|r|u|c|m|o|p|v|x|+|!|*] <LogFile>
    i - Status messages
    w - Nonfatal warnings
    e - All error messages
    a - Start up of actions
    r - Action-specific records
    u - User requests
    c - Initial UI parameters
    m - Out-of-memory or fatal exit information
    o - Out-of-disk-space messages
    p - Terminal properties
    v - Verbose output
    x - Extra debugging information
    + - Append to existing log file
    ! - Flush each line to the log
    * - Log all information, except for v and x options
    /log <LogFile>
    Equivalent of /l* <LogFile>
    Update Options
    /update <Update1.msp>[;Update2.msp]
    Applies update(s)
    /uninstall <PatchCodeGuid>[;Update2.msp] /package <Product.msi | ProductCode>
    Remove update(s) for a product
    Repair Options
    /f[p|e|c|m|s|o|d|a|u|v] <Product.msi | ProductCode>
    Repairs a product
    p - only if file is missing
    o - if file is missing or an older version is installed (default)
    e - if file is missing or an equal or older version is installed
    d - if file is missing or a different version is installed
    c - if file is missing or checksum does not match the calculated value
    a - forces all files to be reinstalled
    u - all required user-specific registry entries (default)
    m - all required computer-specific registry entries (default)
    s - all existing shortcuts (default)
    v - runs from source and recaches local package
    Setting Public Properties
    [PROPERTY=PropertyValue]
    Consult the Windows ® Installer SDK for additional documentation on the
    command line syntax.
    Copyright © Microsoft Corporation. All rights reserved.
    Portions of this software are based in part on the work of the Independent JPEG Group.
    Please use plain text.
    Member
    Re: Just Installed Inventor 2013...
    01-26-2013 11:04 AM in reply to: trevor.freeman
    wow, 3 hours and nothing?
    Member
    01-28-2013 06:46 AM in reply to: trevor.freeman
    really. no response? I thought autodesk staff were active here? I posted this saturday at like 8:45 am? now its time to go to school yet nothing is done, thanx alot autodesk support
    *Expert Elite*
    DarrenP
    01-28-2013 06:48 AM in reply to: trevor.freeman
    windows 8 is not a supported OS anyway
    Member
    01-28-2013 06:57 AM in reply to: DarrenP
    well isnt that nice, only spoke to 10 different people on the phone, and sent a support ticket  that came back this morning with instructions on how to fix it, and your saying it doesn't work? My teacher is usuing windows 8, right up on the whiteboard with this?
    *Expert Elite*
    TravisNave
    01-29-2013 10:00 AM in reply to: trevor.freeman
    That is correct.  Use Windows 7 or Windows XP.  Windows 8 is not supported for Inventor 2013.  I suspect Inventor 2014 will support Windows 8.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
