Installation & Licensing
camkiki
262 Views, 1 Reply
Issues installing Maya
I just finished using the free trial, uninstalled everything and attempted to download the student version for 3 years. I successfully set up the account, got my serial number and product key but every time I've tried to install, the download fails. I know my computer is eligible because I've been using Maya for the past month but I keep running into errors. I need this program for a class and need to know what I can do to troubleshoot. Any help is greatly appreciated.
Tags (3)
1 REPLY 1
TravisNave
in reply to: camkiki
You're not the only one having this issue.  I wrote about it here:
http://forums.autodesk.com/t5/Installation-Licensing/Download-Failed-Installation-aborted-Result-160...
Hopefully that will get you up and running.
Good Luck!
Autodesk Forums:
Administrator Productivity
