I am attempting to install the Building Design Suite 2014 using my company's Home Use License. When I try to install, it will insatll Revit, Navisworks and Recap, but not AutoCAD. I get an error reading"this program and its prerequisites do not support the selected language," or something like that. I have try installing and uninstalling twice. I spoke with my IT guy to make sure I did a true uninstall, and it seems I followed all the correct protocal. When I attempt to install, I get the following (please see attached).
Thank you so much, in advance for your help.
Please try the following:
1.rename following folders, if you find then on your system (e.g old_original_folder_name).
C:\ProgramData\Autodesk\AutoCAD 2014
C:\Program Files\Autodesk\AutoCAD 2014
C:\Users\your_user_name\AppData\Local\Autodesk\AutoCAD 2014 C:\Users\your_user_name\AppData\Roaming\Autodesk\AutoCAD 2014
2.export following registry keys (if you find them in your system registry) as .reg files for back up purposes and then delete them in registry. To open your system registry editor, go to Search > type regedit and hit Enter key.
HKEY_CLASSES_ROOT\Installer\Products\7D2F3875100D0000102000060BECB6AB
HKEY_CLASSES_ROOT\Installer\Products\7D2F3875100D9040112000060BECB6AB
HKEY_CLASSES_ROOT\Installer\Products\7D2F3875100D9040122000060BECB6AB
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R19.1\ACAD-D001
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R19.1\ACAD-D001:409
HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\R19.1\ACAD-D001
HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\R19.1\ACAD-D001:409
HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\R19.1\AutoCAD 2014 - English
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\7D2F3875100D0000102000060BECB6AB
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\7D2F3875100D9040112000060BECB6AB
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\7D2F3875100D9040122000060BECB6AB
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{5783F2D7-D001-0000-0102-0060B0CE6BBA}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{5783F2D7-D001-0409-1102-0060B0CE6BBA}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{5783F2D7-D001-0409-2102-0060B0CE6BBA}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\AutoCAD 2014 - English
Once you remove above mentioned items, please start ACAD 2014 installation as follows:
1.logon with local system admin account
2.empty your TEMP folder. To open TEMP folder, type %TEMP% in the address bar of Windows Explorer and hit Enter key.
3.disable your antivirus software
4 disable UAC (User Access Control Manager)
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Having the same issue while installing Structural Detailing 2012, "this program and its prerequisites do not support the selected language,"
I had it installed before and worked fine, after uninstalling and re-installing i get this error.
Windows Vista (Home Premium) X64
Service Pack 2
