Hello. I'm a student in architecture. I need to install 2 programs : Revit and 3ds Max Design. I'm having trouble for both.
About Revit : it doesn't even start the installation. I get an error message saying "Some installation files are corrupt. Please download a fresh copy and retry the installation". I've retried a thousand times but every time I get the same message.
About 3ds Max : I could install the program but when I start it I get this : "Autodesk Licensing : file not found : C:/Program Files/Common Files/Autodesk Shared/Adlm/R7/en-US/Webdepot/RTEaseReAuthBeginReg.html "
I click ok, then I get the menu suggesting me to Try or to Activate. If I Try, it works with the trial version. If I activate I get this : "Autodesk Licensing : file not found : C:/Program Files/Common Files/Autodesk Shared/Adlm/R7/en-US/Webdepot/RTBeginReg.html "
I click ok, it tells me that the software license check out failed, error 20.
Can anyone help me ? I tried with autodesk support but what they told me didn't work...
Thanks !
Hello and welcome to Autodesk Forums.
I would suggest downloading 3ds Max and Revit from Autodesk virtual agent and reinstalling both.
A. Download 3ds Max/Revit installer from virtual agent.
1.Go to http://www.autodesk.com
2.At the bottom of the page, beneath Help and Support, click Customer Service.
3.Click the Ask button.
4.In the Virtual Agent window, click Downloading and Installation.
5.Click Software Download links.
6.Click "I need to redownload my product."
7.Click 3ds Max/Revit Products
8.Select the appropriate product and click the link to download.
B. Install 3ds Max/Revit as follows:
1.Logon as an Administrator.
2.Empty your TEMP folder. To open the TEMP folder, type %TEMP% in the address bar of Windows Explorer and hit Enter.
3.Disable your Antivirus software.
5.Install 3ds Max and Revit.
Please let us know if this helps.
It finally worked ! Thanks !
One more thing. Is it possible to change the language to French once the programs are installed ?
Same problem with my 3DS Max Educational License. New installation and disabling Antivirus + UAC don't work, any other idea how to fix this?
I had the same problem with 3dsmax design....searching in the web I've found a solution easier: I'm Italian, the message was "file not found : C:/Program Files/Common Files/Autodesk Shared/Adlm/R7/en-US/Webdepot/RTBeginReg.html" so in the folder R7 I have a folder named it-IT and not en-US, I renamed the folder it-IT in en-US and it works.
GRAAANDEEE ha funzionato anche sul mio...ma si può avere sti problemi con un programma da 3'900€?!?
mck90 escribió:I had the same problem with 3dsmax design....searching in the web I've found a solution easier: I'm Italian, the message was "file not found : C:/Program Files/Common Files/Autodesk Shared/Adlm/R7/en-US/Webdepot/RTBeginReg.html" so in the folder R7 I have a folder named it-IT and not en-US, I renamed the folder it-IT in en-US and it works.
gracias MCK90, funciona tambien para la version en español (carpeta es-Es). Saludos
