Here you go. Is this enough info?
9:36:45 (lmgrd) -----------------------------------------------
9:36:45 (lmgrd) Please Note:
9:36:45 (lmgrd)
9:36:45 (lmgrd) This log is intended for debug purposes only.
9:36:45 (lmgrd) In order to capture accurate license
9:36:45 (lmgrd) usage data into an organized repository,
9:36:45 (lmgrd) please enable report logging. Use Macrovision's
9:36:45 (lmgrd) software license administration solution,
9:36:45 (lmgrd) FLEXnet Manager, to readily gain visibility
9:36:45 (lmgrd) into license usage data and to create
9:36:45 (lmgrd) insightful reports on critical information like
9:36:45 (lmgrd) license availability and usage. FLEXnet Manager
9:36:45 (lmgrd) can be fully automated to run these reports on
9:36:45 (lmgrd) schedule and can be used to track license
9:36:45 (lmgrd) servers and usage across a heterogeneous
9:36:45 (lmgrd) network of servers including Windows NT, Linux
9:36:45 (lmgrd) and UNIX. Contact Macrovision at
9:36:45 (lmgrd) www.macrovision.com for more details on how to
9:36:45 (lmgrd) obtain an evaluation copy of FLEXnet Manager
9:36:45 (lmgrd) for your enterprise.
9:36:45 (lmgrd)
9:36:45 (lmgrd)
9:36:45 (lmgrd)
9:36:45 (lmgrd) pid 3060
9:36:45 (lmgrd) Detecting other license server manager (lmgrd) processes...
9:36:45 (lmgrd) Done rereading
9:36:45 (lmgrd) FLEXnet Licensing (v11.4.0.0 build 31341) started on SYDLIC03 (IBM PC) (6/12/2007)
9:36:45 (lmgrd) Copyright (c) 1988-2006 Macrovision Europe Ltd. and/or Macrovision Corporation. All Rights Reserved.
9:36:45 (lmgrd) US Patents 5,390,297 and 5,671,412.
9:36:45 (lmgrd) World Wide Web: http://www.macrovision.com
9:36:45 (lmgrd) License file(s): C:\License Files\Autodesk\Autodesk.lic
9:36:45 (lmgrd) lmgrd tcp-port 27000
9:36:45 (lmgrd) Starting vendor daemons ...
9:36:45 (lmgrd) Starting vendor daemon at port 2080
9:36:45 (lmgrd) Using vendor daemon port 2080 specified in license file
9:36:45 (lmgrd) Started adskflex (pid 4004)
9:36:45 (adskflex) FLEXnet Licensing version v10.8.0 build 18869
9:36:45 (adskflex) lmgrd version 11.4, adskflex version 10.8
9:36:45 (adskflex) Server started on XXXXXXXX for: 46300ACD_2005_0F
9:36:45 (adskflex) 48200ARDES_2005_0F 46700ARCHDESK_2005_0F 49500BLDSYS_2006_0F
9:36:45 (adskflex) 51200ACD_2007_0F 51800BLDSYS_2007_0F 52800ARDES_2007_0F
9:36:45 (adskflex) 51500ARCHDESK_2007_0F 51700MAP_2007_0F 55800ARCHDESK_2008_0F
9:36:45 (adskflex) 55600BLDSYS_2008_0F 54200REVSU_4_0F PLIST
9:36:45 (adskflex) 533003DSMAX_9_0F
9:36:45 (lmgrd) adskflex using TCP-port 2080
9:36:49 (adskflex) TCP_NODELAY NOT enabled
