I can't get Inventor pro 2012 to install. When I enter the serial number and product key, I got the green check marks, so that does not appear to be the problem. The installation fails almost immediately, with all modules showing a red X. There is no error mentioned in the error log (which is only created for the Design Review module, and is attched).
Any ideas ?
Thanks.
Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
Uninstall any existing or newer VC++ from Control Panel > Programs and start your Inventor install again.
I am having the exact same problem. Where can i download Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603?
You can download it from Microsoft. But the installer will install it for you if you remove it first from Control Panel.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
