Installation & Licensing
Inventor install student version
1 REPLY 1
738 Views, 1 Reply
Im trying to install the 2012 Inventor student edition on my laptop. I have a serial and such but it gives me an error everytime I run the installer, see the log file below:
2012/3/15:18:24:07 Metzler NIENKE === Setup started on NIENKE by Metzler ===
2012/3/15:18:24:07 Metzler NIENKE Launch
2012/3/15:18:24:11 Metzler NIENKE Inventorui== Parameter: Prereq_1 SetupMode:1 InstallState:1 InstallAction:0 Message:
2012/3/15:18:24:11 Metzler NIENKE Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2012/3/15:18:24:11 Metzler NIENKE Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2012/3/15:18:24:21 Metzler NIENKE Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message:
2012/3/15:18:24:21 Metzler NIENKE PageOpen LaunchDialog
2012/3/15:18:25:03 Metzler NIENKE PageOpen LicenseDialog
2012/3/15:18:25:26 Metzler NIENKE PageOpen ProductInfoDialog
2012/3/15:18:25:51 Metzler NIENKE PageOpen InventorFlavorSelectionDialog
2012/3/15:18:25:52 Metzler NIENKE Inventorui==DefaultLanguage: en-us
2012/3/15:18:25:52 Metzler NIENKE Inventorui==InstallName: INVENTOR
2012/3/15:18:25:52 Metzler NIENKE Inventorui==ProductName: Autodesk Inventor 2012
2012/3/15:18:25:52 Metzler NIENKE Inventorui==DisplayName: Autodesk® Inventor® 2012
2012/3/15:18:25:52 Metzler NIENKE Inventorui==DeploymentName:
2012/3/15:18:25:52 Metzler NIENKE Inventorui==SetupTitle: Autodesk Inventor 2012
2012/3/15:18:25:52 Metzler NIENKE Inventorui==ConfigTransform:
2012/3/15:18:25:52 Metzler NIENKE Inventorui==ExeParams:
2012/3/15:18:25:52 Metzler NIENKE Inventorui==ProductCode: {7F4DD591-1664-0409-0000-7107D70F3DB4}
2012/3/15:18:25:52 Metzler NIENKE Inventorui==SupportLink:
2012/3/15:18:25:52 Metzler NIENKE Inventorui==InfotainmentLink:
2012/3/15:18:25:52 Metzler NIENKE Inventorui==MsiFileName: inventor.msi
2012/3/15:18:25:52 Metzler NIENKE Inventorui==AdminImageConfigName: AdminImagex64
2012/3/15:18:25:52 Metzler NIENKE Inventorui==AdminImageRoot:
2012/3/15:18:25:52 Metzler NIENKE Inventorui==GetBaseDeploymentName:
2012/3/15:18:25:52 Metzler NIENKE Inventorui==DeploymentLocation:
2012/3/15:18:25:52 Metzler NIENKE Inventorui==DocumentLink: SetupRes\InfoLink\help_landing.html
2012/3/15:18:25:52 Metzler NIENKE Inventorui==InstallDeploymentShortcut:
2012/3/15:18:25:52 Metzler NIENKE Inventorui==ModifyDeploymentShortcut:
2012/3/15:18:25:52 Metzler NIENKE Inventorui==SetupLockType: 2
2012/3/15:18:25:52 Metzler NIENKE Inventorui==SetupNetworkType: 0
2012/3/15:18:25:52 Metzler NIENKE Inventorui==SystemLocale: 1043
2012/3/15:18:25:52 Metzler NIENKE Inventorui==EvalMsiFilePath: C:\Users\Metzler\AppData\Local\Temp\_AI85E1.tmp\SetupRes\eval.msi
2012/3/15:18:25:52 Metzler NIENKE Inventorui==EulaPath: C:\Users\Metzler\AppData\Local\Temp\_AI85E1.tmp\EULA
2012/3/15:18:25:52 Metzler NIENKE Inventorui==InstallLogPath: C:\Users\Metzler\AppData\Local\Temp\Inventor2012Install.log
2012/3/15:18:25:52 Metzler NIENKE Inventorui==ConfigFile: C:\Users\Metzler\AppData\Local\Temp\_AI85E1.tmp\Setup.ini
2012/3/15:18:25:52 Metzler NIENKE Inventorui==SetupPath: C:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\
2012/3/15:18:25:52 Metzler NIENKE Inventorui==NetworkLogPath:
2012/3/15:18:25:52 Metzler NIENKE Inventorui==SourceRoot: C:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\
2012/3/15:18:25:55 Metzler NIENKE Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2012/3/15:18:25:55 Metzler NIENKE PageOpen ProductSelectionDialog2
2012/3/15:18:26:18 Metzler NIENKE PageOpen FullProgressDialog
2012/3/15:18:26:18 Metzler NIENKE Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\Metzler\AppData\Local\Temp\vcredist_x86_2010.log
2012/3/15:18:26:21 Metzler NIENKE Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
1 REPLY 1
TravisNave
Uninstall your Visual C++ from Control Panel > Programs and run the Autodesk installer again.
Autodesk Forums:
Administrator Productivity
