Good Morning,
I am trying to install the Inventor 30 days trial version. So far, I downloaded and installed the Inventor and got it installed on my PC. Currently, I am capable of clicking on the Autodesk design review ICON and the program does start.
However, when clicking on the Inventor Fusion 2012 ICON, I am getting the following message: The application is unavailable. No license available. License does not exist or has expired.
Currently, I was able to install the Inventor fusion SP1. I did try to install the Inventor Fusion SP2, but this was not successful, and I am not sure why.
Also, I completed the .net 4.0 routine as required.
Currently, I am using Windows Vista 2006 and I never upgraded this OS. Is this required for correctly being able to work with Inventor Fusion 2012?
So, your help will be appreciated for the above issue and question.
Etienne Munger
If you need KB971138, you can find it here.
You need the 32-bit version:
http://forums.autodesk.com/autodesk/attachments/autodesk/24/35165/1/Windows6.0-KB971138-x86.zip
