Installation & Licensing
Inventor freezes before activation with GTX 660
4 REPLIES 4
robm1983
322 Views, 4 Replies
Hi gusy,
I got Inventor Pro 2014 and the GTX 660 card. When I run inventor to activate it, it would freeze.
I had read about a similar problem here http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Autodes... they suggest to "Run with Graphics processor", but I don't have it, when I right-click the icon.
Tried also tips from here http://knowledge.autodesk.com/support/inventor-products/troubleshooting/caas/sfdcarticles/sfdcarticl...
without any results.
If I would boot in safe mode, inventor would simply hold the loading window for a few seconds and close.
What would you suggest?
Thanks guys.
R
4 REPLIES 4
robm1983
in reply to: robm1983
Ouch, I placed an old video card into the new PC, but the results are still the same. 😞
robm1983
Win7, 64-bit
AMD FX 8350, 8 core
tried both on ARI Radeon HD 3870 and GTX 660
robm1983
I just formatted the primary SSD, disconnected the secondary and installed fresh windows 7, 64bit. Still the same, freezes when loading.
in the INVPROSA2014ENUAdlm.log file I get this.
1232    2014/06/24    14:14:54    Reason=Fatal error
1232    2014/06/24    14:14:54    ComputerName=ROBERT-PC
1232    2014/06/24    14:14:54    OS=6.1.7600.
1232    2014/06/24    14:14:54    File=AdlmIntSATSLicense.cpp,Line=474
1232    2014/06/24    14:14:54    VendorID=2 [ADLMACT]
1232    2014/06/24    14:14:54    VendorError=101 [The license cannot be accessed/loaded/opened]
when I removed the file
-erase C:\ProgramData\FLEXnet
-erase C:\ProgramData\Autodesk\Adlm
( as suggested here http://forums.autodesk.com/t5/AutoCAD-2010-2011-2012/AutoCAD-2011-crashes-immediately/td-p/2787094 )
the loading windows just poped up and disappeared, without freezing. in the log file I get this
5028    2014/06/24    18:21:03    Reason=Fatal error
5028    2014/06/24    18:21:03    ComputerName=ROBERT-PC
5028    2014/06/24    18:21:03    OS=6.1.7600.
5028    2014/06/24    18:21:03    File=AdlmIntLicenseMgr.cpp,Line=447
5028    2014/06/24    18:21:03    VendorID=6 [ADLMPIT]
5028    2014/06/24    18:21:03    VendorError=24 [Unable to locate the Product Information Table File]
5028    2014/06/24    18:21:03    File=AdlmIntLicenseMgr.cpp,Line=448
5028    2014/06/24    18:21:03    AdlmIntError=41 [Product Information Table file is not found]
5028    2014/06/24    18:21:03    File=AdlmIntLicense.cpp,Line=590
5028    2014/06/24    18:21:03    File=AdlmIntLicense.cpp,Line=591
but once reinstalled again, the old freezing continues.
robm1983
yet in C:\ProgramData\FLEXnet i see adskflex_00691b00_event.log , which has
20:15:38 24-06-2014  [P:1440],[T:1772]     EventCode: 20000009, Message: The service is incorrectly configured, reinstall
20:15:38 24-06-2014  [P:1440],[T:1772]     Exception: 59, Module: f0000, Location: 10
Administrator Productivity
